adz_sportif_turbo Posted September 9, 2010 Posted September 9, 2010 i have a cold start idle of about 1500,,,and wen warm not 2 much lower,,,wen i squeeze the icv pipe the idle drops,,,does it sound like a icv failing?? does anyone know wat resistance should be running to the valve on cold start etc?? i have 12v and a resistance signal wire. i cleaned out the icv with an airline and the idle dropped,,,untill i plugged it in and it raised again,,,obv because the plunger moved wen i forced air in it,,,any ideas tho?!?regardsadam Quote
james@cjperformance Posted September 10, 2010 Posted September 10, 2010 i have a cold start idle of about 1500,,,and wen warm not 2 much lower,,,wen i squeeze the icv pipe the idle drops,,,does it sound like a icv failing?? does anyone know wat resistance should be running to the valve on cold start etc?? i have 12v and a resistance signal wire. i cleaned out the icv with an airline and the idle dropped,,,untill i plugged it in and it raised again,,,obv because the plunger moved wen i forced air in it,,,any ideas tho?!?regardsadami have an icv hear you can have buddy if you cover postage, try that and see if it makes a difference. Quote
Socks Posted September 10, 2010 Posted September 10, 2010 might just be worth trying to lover the idle speed on the screw near the throttle body? See if that solved your problem... Quote
adz_sportif_turbo Posted September 10, 2010 Author Posted September 10, 2010 i have an icv hear you can have buddy if you cover postage, try that and see if it makes a difference. that would b brill if u cud do that mate!! pm me your paypal addy and the cost might just be worth trying to lover the idle speed on the screw near the throttle body? See if that solved your problem...i was thinkin this if changin the icv doesnt work,,,fingers crossed tho it does the job Quote
Socks Posted September 10, 2010 Posted September 10, 2010 id try turning a screw before replacing somthing :s Quote
LukeSR Posted September 10, 2010 Posted September 10, 2010 id try turning a screw before replacing somthing :sThis Quote
adz_sportif_turbo Posted September 18, 2010 Author Posted September 18, 2010 Sorted!! Idle screw to the rescue Quote
