Bit quiet on here atm with people getting back from JAE/going back to work etc give it till later during the day
Id say something like oil temp....
Personal preference really, what do you want to be looking at, how much effort do you want to put in setting it all up?
Safety wise, oil pressure, oil temp and water temp would all be most important. Oil gauges are a ball ache to plumb in properly though, water gauges a little easier.
If you just want something pretty to look at thats easy to fit, go for a volt gauge or a rev gauge.
All depends what you want really!
Id say a AFR isnt really needed, unless your running a mad V and are constantly needing to keep an eye on her.....if its just a double pod boost + oil temp or locate the boost one elsewhere and go for oil temp + water temp
im not planning on going crazy bu 200 bph max, just want something usefull and safety is probs what im after i dony know whay an afr is !lol dose anyone know whats needed for oil temp guage? or will it most likely be with the guage?
