birdmandan Posted September 30, 2010 Share Posted September 30, 2010 Hey guys so after a good drive in my glanza tonight, i come to stop put her in neutral and then i start to hear this wierd sort of hollow scraping/grinding noise from under the bonnet that i can clearly hear in the car and outside! Now the noise seems to be coming from the pulley area where all pulleys and belts are! I have no idea what this could be! The scraping noise is in time with the engine revs and becomes less noticables when going higher revs because of engine noise drowning it out but im guessing its there all the time. This noise has started to get a little louder each time i listen for it ;)Has anyone ever experienced a problem like this before? i am totally confused and scared that my engine is going to break again! ( my bottom end went a month ago) So yeah guys what you think? Any help and replies will be Fully appreciated!!Thanks in advance, Dan :confused: Quote Link to post Share on other sites
1987glanza Posted September 30, 2010 Share Posted September 30, 2010 sounds like it could possibly by your water pump, try taking the aux belts off and start it see what happens, if the niose is still ther could be down to your tensioner on the timing belt. hope this will help...marc Quote Link to post Share on other sites
lukEp Posted September 30, 2010 Share Posted September 30, 2010 Clutch release bearing mine make a noise when the clutch is released but not when pressed. Quote Link to post Share on other sites
Nanglebadger Posted September 30, 2010 Share Posted September 30, 2010 ^^^^ditto Luke.Phil. Quote Link to post Share on other sites
birdmandan Posted September 30, 2010 Author Share Posted September 30, 2010 Sorry forgot to mention that I don't think its geaebox related because it does it clutch pressed down and with cluth up.. :s Quote Link to post Share on other sites
