gtmuzz Posted October 27, 2010 Posted October 27, 2010 I'm considering teaching myself to weld, I have ZERO experience in welding but think its a good thing to know how to do So basically do you think this would be a good beginner kit to learn with ??Have a look Please price seems good, and the reviews seem no badI know alot of peeps on this site know alot about this stuff so help with it would be smashing Cheers Quote
james@cjperformance Posted October 27, 2010 Posted October 27, 2010 I'm considering teaching myself to weld, I have ZERO experience in welding but think its a good thing to know how to do So basically do you think this would be a good beginner kit to learn with ??Have a look Please price seems good, and the reviews seem no badI know alot of peeps on this site know alot about this stuff so help with it would be smashing Cheersif i were you buddy i would keep your eye out on the bay for a half tidy mig to learn with.i found it so easy to pick up.some will disagree im sure but with a mig if you cant get on with it you can allways sell it on for pretty much what you paid for it.if you go for a mig get a gas mig as gasless are crap and the wire is extautionate.to practice on i used a meter of angle iron and just cut it into chunks and weld bit on so you get the feel for it and the plus point is if you get into it you can make pretty much anything you want. Quote
gtmuzz Posted October 27, 2010 Author Posted October 27, 2010 if i were you buddy i would keep your eye out on the bay for a half tidy mig to learn with.i found it so easy to pick up.some will disagree im sure but with a mig if you cant get on with it you can allways sell it on for pretty much what you paid for it.if you go for a mig get a gas mig as gasless are crap and the wire is extautionate.to practice on i used a meter of angle iron and just cut it into chunks and weld bit on so you get the feel for it and the plus point is if you get into it you can make pretty much anything you want.cheers bud i'll see whats there, not sure the difference between all the different types yet so probably just shop about getting as much info as possible first , I know what you mean, I can pick up most things pritty easily lol I've always wanted to be able to do it and while ive got some money I think I should invest it in something like this lol Quote
james@cjperformance Posted October 27, 2010 Posted October 27, 2010 clickyhave a look on there all the info you could need.put up an intro on there and see whats what.they are pretty helpfull to be fair.i will warn you now that it is higly addictive ha ha.you will end up welding whatever you can get your hands on lol Quote
gtmuzz Posted October 27, 2010 Author Posted October 27, 2010 clickyhave a look on there all the info you could need.put up an intro on there and see whats what.they are pretty helpfull to be fair.i will warn you now that it is higly addictive ha ha.you will end up welding whatever you can get your hands on lol Wow a whole forum on welding! looks like ive got alot of reading to do lol cheers mate Haha hopefully welding will get me out of my cable tie fetish Quote
Driver Posted October 27, 2010 Posted October 27, 2010 Welding is something ive allways wanted to do and allthough i did learn myself to arc a while ago its been a while since i picked up a stick so im starting from scratch haha.Im with the above remark though ide go with Mig if i was you, ive done some mig and its fairly easy to pick up but be prepared to waste alot of metal, filler and gas before having acceptabel welds haha.Ive finally got some money together and bought myself a 160amp AC/DV Tig welder aswell Currently boxed up in my room awaiting finding some gas, ordering my foot pedal and sitting down to waste so scrap hahaGood luck and keep us updated. Quote
nastyrash 2003 Posted October 28, 2010 Posted October 28, 2010 yep mig and tig are the easyer to do, you can get a mig quite cheap, but remember never weld out side and with mig you can use co2 gas, which is very cheap, and can also weld stainless and alli. Quote
james@cjperformance Posted October 28, 2010 Posted October 28, 2010 yep mig and tig are the easyer to do, you can get a mig quite cheap, but remember never weld out side and with mig you can use co2 gas, which is very cheap, and can also weld stainless and alli.i was allways under the impression you needed tig to weld alli?am i wrong?hmmmm i will have a go later.as for gas nip down to your local pub and ask them if you can buy a c02 gas bottle off them as they get it for pennys, i paid £20 for a full size c02 bottle, size is 120cm tall x 23 cm diameter, i have had that bottle for well over a year. Quote
the quiet achiever Posted October 28, 2010 Posted October 28, 2010 hi all welding is a process of learning the process&then lots of practice . in my case i learnt to arc weld & oxy- acetylene welding with a hobby course @rhe local TAFE college with the basics of welding learnt &lots of practice you can then teach yourself to weld using the tig &mig process the tig &mig process can be adapted to weld all sorts of material as different gases are required to weld the various materials ie ali requires pure argon whereas the various steels can be welded using CO@ or other gas blends so you see there is more to using the various welding processes than simply buying a welder &then start praticising there is all the knowledge & lots of practice before you can make a passable /servicable weld good luck with your desire to learn to weld the various metals. it won`t necessarily be easy /but also fustrating as your welding gets better lyle Quote
federalman Posted October 28, 2010 Posted October 28, 2010 Arc welding is ok but you can risk it blowing through on thin steel. Your best bet is to get a mig kit around 120 amp single phase kit it gives a smooth weld. Don't bother with a gasless mig the whole idea with mig is the gas surrounds the weld which gasless won't do. You can get a wolf weld gas mig kit off eBay for around 180 delivered Quote
Dean @RW-Developments Posted October 28, 2010 Posted October 28, 2010 tbh mate as said above if your just looking to weld steal then get a mig there really easy to use, but make sure you get a gas mig as i have a non gas mig and it just spits its pure shit and expensive for wire! plus depending on what your welding you will only beable to weld that desired metal unless you buy lots of reals of different wires for different materialsARCi also have an arc welder which is great if your welding thick metal but thin stuff requires real skill ive welded all sorts with it but the metal has to be really clean, realistically you need to be welding 3mm thick plus! theres no triger etc just set the welder then strike the rod like a match, it can be a rite pain getting a weld started unless stupidly clean mental is being used.TIGok this is what i do for a job as im an aluminium welder and fabricator. this would be the welder you would use for all different materials i.e alloy, steal, cast, stainless steal etcall you need to do is change the settings on the welder and use different filler rod etc.there is alot more to tig welding as you have to angle your torch at 45 deg whilst moving it foward adding your rod in sequence and operating your foot pedal much like a car clutch, this is not really the sort of welder for getting an insite into welding....the main thing is practice and lots of it that goes for any sort of weldera tig welder would be used to create amazing looking welds like pieces of art it leaves the desived bead where the weld is perfectly folded( platted) ebay is the best bet but dont buy 2 cheap Dean Quote
gtmuzz Posted October 28, 2010 Author Posted October 28, 2010 Cheers lads thats helped me out alot!! Motherwell college do a 10 week course on practical welding (no qualifications at the end of it) aimed totally at people wanting to do it as a hobby its £70 and on wednesday nights. Only problem is, it only runs from late september each year so missed this year . I signed up but was moving house at the time and they sent all the enrolment/payment stuff to my old address so missed out i'll b going next year though That sounds good bud!, i'll have a wee look into it cheers Quote
BigMan Posted October 28, 2010 Posted October 28, 2010 i fancy doing welding, have done for a while, it intrests me for some reason lolmurray if ya find out about a course that we can do near us let me know as might be intrested. Quote
