At the moment I'm running the following Mods:
FMIC
Front air filter relocation
HKS SSQV
HKS Actuator set @ 1 Bar
JAM ECU
Decat and SPS Mani
Straight Through Exhaust system
Im worried about running it lean with no fueling mods, especially with the ECU?
I think im going to invest in a A/F ratio gauge, but is it worth getting a RRFPR and Fuel pump? even with the ECU?
Any advice would be appriciated
thanks
Dont bother with a RRFPR, but i would suggest a fuel pump just to be on the safe side.
Then pop to a local Rolling road for a check on the air/fuel ratio etc
Guest cheshireglanza
will the jam ecu not sort the fueling up to 1.2 bar
Yep agree with above get you self a fuel pump then get your self to the RR and see how she's fueling.I had a Blitz Ecu on my old glanza and the only time i've ever heard of anyone useing a FPR is when they advance the timeing abit (TO GET ABIT MORE POWER OUT OF IT)as the blitz ecu's run rich at the top end which kills the power abit.
