My sportif needs new front brakes, and when i took the pads out they were both the same, so went to a scrappys and on a starlet of the same year, but a five door version, the calipers were different and one of the pads was a different shape completely? like curved with longer arms? can anyone shed some light on this and which pads are best for my car.
MODS: I know it should be in brake section, but im desperate for these!
Thanks
i'd say possibly not if the pad is a much different shape.
the earlier EP91s had different calipers to the later spec ones (1998 onwards) which had the same calipers as the glanzas.
for the price of EBC or even blueprint oem replacement pads i wouldnt be fitting pre-used pads anyways man. why bother.
Phil.
Thanks mate, im sure they look the same, only had mine off last week so i think there the right ones! the caliper itself can come away from that thin bar when you unbolt the bolts from the sliders if you get me? if thats right then them calipers should fit lol
im sure thers only 2 sizes of brake anyway. either u have the smaller discs ( just measure em ) they wont fit glanza stuffs . or ya have the bigger ones which are the same.
be careful as alot of companys will just sell as a brake kit for ep91 even tho there are different sizes
Im not too sure either way, like i said the N/A of the same year as mine had completely different calipers, while these ones i have bought look exactly like mine? either way will they fit the mounts on my car?
Thanks
abit weired as far as i was aware theres 3 different brake setups for na's theres the early brakes then theres the later brakes like that was on my 97 sportif that were 238mm disc (not the same as glanza i dont think??) then the sr brakes were bigger and possibly the same as glanza/gt brakes at 254mm
i fitted paseo brakes on my sportif that are apparently the same as gt brakes etc but when i fitted them i changed the front hubs and driveshafts as they have thicker shafts and the hubs had a different spline count...... so better when running the 4efte
anyway sorry for the babble lol
Dean
