harrijones Posted November 27, 2010 Posted November 27, 2010 As above is this worth buying? http://www.tm-developments.com/index.php?m...;products_id=10and if so is it easy to fit and will i de-restrict the car ? Quote
aaddzz123 Posted November 27, 2010 Posted November 27, 2010 Brilliant little unit mate! Bought a similar one off ebay and I can't fault it one bit. Very accurate and easy peasy to fit. You just unscrew the speedo cable from the gearbox (easily done by hand) and screw the converter onto the gearbox, and put the cable back into the converter... So basically just put the converter between the gearbox and the cable. 10 minute job literally. 100% reccomended and yes it will derestrict your speed limit unless you manage to do what.... 190mph ish lol! Quote
starlet1.3si Posted November 27, 2010 Posted November 27, 2010 Brilliant little unit mate! Bought a similar one off ebay and I can't fault it one bit. Very accurate and easy peasy to fit. You just unscrew the speedo cable from the gearbox (easily done by hand) and screw the converter onto the gearbox, and put the cable back into the converter... So basically just put the converter between the gearbox and the cable. 10 minute job literally. 100% reccomended and yes it will derestrict your speed limit unless you manage to do what.... 190mph ish lol!I've just ordered a external rev gauge, any chance you no how easy that is to fit? Quote
Amjad Posted November 27, 2010 Posted November 27, 2010 aaddzz123 you got a link for the Ebay one? Need one cheap as possible Quote
aaddzz123 Posted November 27, 2010 Posted November 27, 2010 aaddzz123 you got a link for the Ebay one? Need one cheap as possible http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=230554158103 There we go mate ...Sorry pal but I have no idea how to fit the RPM gauge lol. I assume you need to wire it into the current RPM clock which probably isn't too hard if you take the clocks out and see what wire goes where.... I'd recommend starting a new thread for that though to get a better response. Quote
harrijones Posted November 27, 2010 Author Posted November 27, 2010 Brilliant little unit mate! Bought a similar one off ebay and I can't fault it one bit. Very accurate and easy peasy to fit. You just unscrew the speedo cable from the gearbox (easily done by hand) and screw the converter onto the gearbox, and put the cable back into the converter... So basically just put the converter between the gearbox and the cable. 10 minute job literally. 100% reccomended and yes it will derestrict your speed limit unless you manage to do what.... 190mph ish lol!Aww brill cheers mate so what mph have you topped you starlet out at? Quote
