rite guys this morn i checked my engine management as i had some lights come on not too long ago,
the codes wer :
34 and 42
34 says is turbo boost pressure and im guessing that means fuel cut?
but 42 says coolent is over 80 degrees between 2000-5000 revs?? what do i do with that????
what you guys reccomend i do?
i knoww i knoww im a fuss pants!
cheers josh
any chance it might just be a loose connection? how will i no if it sorts it? go for a long drive and see if the engine light goes bak on?
cheers for the help guys! gotta get it sorted before christmas as im driving down to the coast :/
the coolant temp sensor wont have anything to do with it overheating, the temp gauge on the dash will let you know that, and the thermo will deal with the temperature.
it will be fine to drive, but your idle will be erratic.
