Andrew Miller Posted December 21, 2010 Share Posted December 21, 2010 Can someone please list the items i need to run a bar of boost on the ct9 please . Ive already got a hks hi-silent, japspeed mani and decat, fmic, hks actuator and hks ssqv. Any help would be great . Ta. Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 fuel pressure reg fuel cut defenderfront mount decat mani upgradinghks actuator Quote Link to post Share on other sites
Andrew Miller Posted December 21, 2010 Author Share Posted December 21, 2010 fuel pressure reg fuel cut defenderfront mount decat mani upgradinghks actuatorOk so basically fpr and fcd. I have the chance to get hold of a apexi safc is that worth getting? ? Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 fuel pressure reg fuel cut defenderfront mount decat mani upgradinghks actuatorRPR and FCD is considered the "crude" and cheaper waydo it cheap do it 2ce. get proper management like plug and play ecu much better Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ or you could do what steve said self leaner ecu jam,biltz,mines which cost from £400 to £500 then there's emange blue but i ran fcd and fpr for years with no issue Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 how many starlets have you killed? Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ killed more with the so called better buy stand alone ecu Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 shows its not the set-up then just the driver Right my list of things requiredUprated maniDecatAftermarket cat backAdjustable actuatorboost set at 1.1 barAir filter relocation KitFront mount intercoolerMagnecore uprated leadsIridium spark plugs Plug and play ecuWalbro or tuning developments uprated fuel pump(also remove the aircon much better without) Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ lol now now FATassracer69 some one has to keep chris in work Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 sorry Chershireglanzabreaker Quote Link to post Share on other sites
micky boy Posted December 21, 2010 Share Posted December 21, 2010 Dont listen to paul he will blow your Engine up It all depends on what set up you are after realy and how deep your pockets are.This is what set up i've had on my Glanza's and its been sweet and never missed a beat!Engine specTRD Engine mountsBlitz Access ECUBlitz DecatRace-Tech Stainless Steel Braided Oil Feed/ReturnZisco compact Manifoldkakimoto exhaust Systemwalbro fuel pumpAir Filter Relocation KtHKS ssqv blow off valveJP Front Mount IntercoolerHKS Actuator @ 1barUltra HT leadsiridium Spark Plugs heat range 7Exedy clutch Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 yes i forgot to mention Braided oil line deffo a good thing to buy when increasing boost you dont want that thing to go lol Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ yes markoos can tell you what happens when that bad boy gives away Quote Link to post Share on other sites
Andrew Miller Posted December 21, 2010 Author Share Posted December 21, 2010 Its starting to get expensive haha . I dont have the money for the ecu unfortunantly. My plan was to get the fcd and fpr and get it fitted and checked on a dyno to make sure it was fueling right etc. I use my car everyday but its only ragged now and again so i thouht this would be ok? ? Also on the subject of the apexi safc are they anygood? Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ yes you will be fine dude with that setup just get it checked out and i have never used apexi safc so cant help you there Quote Link to post Share on other sites
micky boy Posted December 21, 2010 Share Posted December 21, 2010 I would rather save for the ECU worth every penny...Im thinking of buying a bog standared glanza soon and the first thing i will be buying befor anything is an ECU the thing i dont like about FCD'S is if it decides to stop working. Quote Link to post Share on other sites
_shaun_ Posted December 21, 2010 Share Posted December 21, 2010 def updrate the oil feed/ return had mine break gave me a nasty scare also might aswell relocate your air filter and on a totaly unrelated matter i have a race-tech oil feed/return and brand new monster motorsport relocation kit here for sale Quote Link to post Share on other sites
Socks Posted December 21, 2010 Share Posted December 21, 2010 very rare a starlet get over 200bhp on stock engine and turbo with a fuel pressure reg and fuel cut defender...majority get 170-180bhp...plug n play ecus if yourrunning stock engien and turbo are totally worth there money and with support mods at the MMRR day, all of the cars running them got over 195bhp... mine got 202bhp... as said save up u wwill be impressed Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 plus by the time youve bought a FCD, RRFPR and had it dyno'd your nearly at the same money as a cheapish plug and play would be Quote Link to post Share on other sites
Andrew Miller Posted December 21, 2010 Author Share Posted December 21, 2010 I just dont have the money for a ecu and getting it fitted etc. Ill go with fcd and just be careful i think. Defo upgrade the oil feed line. As for relocating kit. I had one but boost creep was awful lol so put efi pipe back on. Wastegates ported asmuch as it can be aswell Quote Link to post Share on other sites
Socks Posted December 21, 2010 Share Posted December 21, 2010 braided oil lines can be found here matey:http://www.race-tech.net/index.php?main_pa...9243358f462c4ff Quote Link to post Share on other sites
Steve GT Posted December 21, 2010 Share Posted December 21, 2010 time to fit a plug and play ecu- 2-5 minutestime to fit a fcd-rrfpr and have it dynoed- 1-2 dayssimples Quote Link to post Share on other sites
Guest cheshireglanza Posted December 21, 2010 Share Posted December 21, 2010 ^^ time to find self leaner ecu weeks Quote Link to post Share on other sites
_shaun_ Posted December 21, 2010 Share Posted December 21, 2010 weeks is an understatement lol tho has to be the fastest beast mod to do lol Quote Link to post Share on other sites
Andrew Miller Posted December 21, 2010 Author Share Posted December 21, 2010 I just dont have £400 to spend on it at one time . Ill maybe try get one next winter or something. Fcd will do for now lol. Quote Link to post Share on other sites
