theminiguru Posted December 21, 2010 Share Posted December 21, 2010 im thinking of changing my coolant and would like to know the best way to bleed the radiator on a glanza. not quite sure how to do it and i wouldnt want to make my car overheat by not bleeding it correctly! if someone knows of a thread i could follow that would be great!any advice will be appreciated.thanks Quote Link to post Share on other sites
daz gt turbz Posted December 21, 2010 Share Posted December 21, 2010 Toyotas are possibly the easiest to bleed, ever. Drain old coolant. Fill with new coolant, run engine till heaters are hot and fan cuts in (and off again) Top up as required to finish.bish, bash, bosh Quote Link to post Share on other sites
Guest cheshireglanza Posted December 22, 2010 Share Posted December 22, 2010 Toyotas are possibly the easiest to bleed, ever. Drain old coolant. Fill with new coolant, run engine till heaters are hot and fan cuts in (and off again) Top up as required to finish. Quote Link to post Share on other sites
theminiguru Posted December 23, 2010 Author Share Posted December 23, 2010 Toyotas are possibly the easiest to bleed, ever. Drain old coolant. Fill with new coolant, run engine till heaters are hot and fan cuts in (and off again) Top up as required to finish.k buddy...spot on!cheers Quote Link to post Share on other sites
theminiguru Posted December 24, 2010 Author Share Posted December 24, 2010 k buddy...spot on!cheers prob sounds like a stupid question but do i fill the cooling system via radiator like you normally would, or do you fill the expansion/overflow tank (the one to the right of the radiator that has the pipe leading off it to the radiator!)thanks Quote Link to post Share on other sites
daz gt turbz Posted December 24, 2010 Share Posted December 24, 2010 prob sounds like a stupid question but do i fill the cooling system via radiator like you normally would, or do you fill the expansion/overflow tank (the one to the right of the radiator that has the pipe leading off it to the radiator!)thanksyep fill the radiator mate. Quote Link to post Share on other sites
Stulet-GTT Posted December 24, 2010 Share Posted December 24, 2010 Toyotas are possibly the easiest to bleed, ever. Drain old coolant. Fill with new coolant, run engine till heaters are hot and fan cuts in (and off again) Top up as required to finish.High 5...Yer i know eveny one else has quoted this but i jus wanted to join in... Quote Link to post Share on other sites
theminiguru Posted December 24, 2010 Author Share Posted December 24, 2010 yep fill the radiator mate.cheers buddy...great help...appreciated Quote Link to post Share on other sites
