G4V1N Posted December 23, 2010 Posted December 23, 2010 Is it possible to drive the car when its misfire, with out causing too much damage?Resent for this, is I need to get the car to have a compression test done. Quote
micky boy Posted December 23, 2010 Posted December 23, 2010 Would you go for a jog if your heart was missing a beat?..I think not lol just get the car toad or get someone to come out and do compreesion test just to be on the safe side Quote
Socks Posted December 23, 2010 Posted December 23, 2010 u can buy a compression tester from halfords or local car parts store cheap anyway matey! Quote
G4V1N Posted December 23, 2010 Author Posted December 23, 2010 okey thats cool, the car started to misfire, what could be the problem? Quote
Kennedy Posted December 23, 2010 Posted December 23, 2010 Mine did this, turned out to be some moisture in the spark plugs.Took the spark plugs out and dried it all, worked fine after. Quote
Socks Posted December 23, 2010 Posted December 23, 2010 misfires if they just suddenly start... change the plugs, dizzy & rotorarm, ht leads... in that order. if still missing get it into a garage! Quote
G4V1N Posted December 23, 2010 Author Posted December 23, 2010 thanks mate, thats really helpful. also i was wondering would misfire also cause smoke problem from the exhaust? Quote
Socks Posted December 23, 2010 Posted December 23, 2010 blue smoke:blue smoke is oil in goin thru the system and being burnt....stem seals, piston rings, turbo oil seals can all cause this!black smoke:is unburnt fuel...for some reason its silly rich!white smoke:headgasket usually! Quote
ryan lang Posted December 23, 2010 Posted December 23, 2010 blue smoke:blue smoke is oil in goin thru the system and being burnt....stem seals, piston rings, turbo oil seals can all cause this!black smoke:is unburnt fuel...for some reason its silly rich!white smoke:headgasket usually!white smoke could also be the stupid cold weather we've been having too Quote
G4V1N Posted December 23, 2010 Author Posted December 23, 2010 i've change the turbo, stem seals, and new head gasket. but im still getting smoke each time im driving. but the guy did told me it could be burning any left over oil. Quote
ryan lang Posted December 23, 2010 Posted December 23, 2010 could just be the cold, like all the other topics haha Quote
