(NAS) starlet ep82 Posted December 28, 2010 Share Posted December 28, 2010 Hi!im wanting to knw how to remove the front headlights???its a quadlight model.Thanks! Quote Link to post Share on other sites
Galliano Posted December 28, 2010 Share Posted December 28, 2010 Open your bonnet.With a 10mm socket at the ready, attack the two bolts that are on the front frame with the brackets of the headlights on. Do this both sides and I believe they come away. May need to remove grille aswell, which will also be held on with brackets and bolts on the front frame. Quote Link to post Share on other sites
Amjad Posted December 28, 2010 Share Posted December 28, 2010 You'll need to undo the top bracket, the screw holding the indicator in, slide the indicator out carefully which exposes two nuts on the side of the quad holding it in. Then undo the grille and carefully remove the light! Quote Link to post Share on other sites
(NAS) starlet ep82 Posted December 29, 2010 Author Share Posted December 29, 2010 cheers guy's for the quick replys! AMJAD:- will be fitting your earthing kit tomorrow aswel, it looks soo much better in the flesh Quote Link to post Share on other sites
dan_91 Posted January 1, 2011 Share Posted January 1, 2011 i no its a bit off subject. but still lights. how do you pull your indicators apart and make them into clear indicators.? cheers. Quote Link to post Share on other sites
Amjad Posted January 1, 2011 Share Posted January 1, 2011 Glad you like it Nas Dan I'm not sure I've seen it done on quad indicators, seen a set on Ebay but I think they're squarelight ones Quote Link to post Share on other sites
Kennedy Posted January 1, 2011 Share Posted January 1, 2011 The ep91 indicators are just little plastic clips iirc.Might be the same for the ep82 Quote Link to post Share on other sites
dan_91 Posted January 1, 2011 Share Posted January 1, 2011 Glad you like it Nas Dan I'm not sure I've seen it done on quad indicators, seen a set on Ebay but I think they're squarelight oneshmm. quite A few downsides too having a quadlight isnt there Quote Link to post Share on other sites
BearFaceOfDoom Posted January 1, 2011 Share Posted January 1, 2011 Am I alright to ask how you split your headlights to clean out the crappy misty shet from inside them? lol Quote Link to post Share on other sites
Stulet-GTT Posted January 1, 2011 Share Posted January 1, 2011 i no its a bit off subject. but still lights. how do you pull your indicators apart and make them into clear indicators.? cheers.You need a set from a square light as cant do quad one's...Here this helped me when i done mine...http://www.toyotagtturbo.com/forums/showth...ndicators-(EP82) Quote Link to post Share on other sites
