I can't type with I phone help me
yh, seems to be a common problem with this forums. I just use the quote tags and then post the new topic and go back and edit it.
Using Firefox on Ubuntui and Vista having same problem on iPod aswell.
My phone does the same thing. Its a touch screen Samsung.
I got around it buy clicking the "Toggle HTML Source"(one next to insert special item) button and coding the message from there.
I think i have managed to start new topics from my phone.
Only thing is you will need some basic html coding knowledge.
Good luck hope it works
Mine works fine in FF and on my iPhone.
I think if you go to add new reply the click the icon just above the text box which looks like a refresh symbol it should work as it switches between standard and rich text editor :thumbsup:
toggling the rich text editor usualy solves most problems,
did the op try that?
this should sort our problems guys.
