theminiguru Posted January 10, 2011 Posted January 10, 2011 when i slighlty steer and hit a bump my car makes a slight clunk on the passenger side.would anyone have any ideas what it could be! i havnt had a chance to get under the car and have a look yet...id imagine it will be bushes!any help would be appreciated.thanks Quote
Josh@TunerLifestyle Posted January 10, 2011 Posted January 10, 2011 check hub bolts are tight, i had a clunking and iy was the bolt, it came off on the motorway and the wheel dipped in , scarey stuff! also are you on coilovers? when you get a chance check all is tight and secure, hope this helps! Quote
theminiguru Posted January 10, 2011 Author Posted January 10, 2011 check hub bolts are tight, i had a clunking and iy was the bolt, it came off on the motorway and the wheel dipped in , scarey stuff! also are you on coilovers? when you get a chance check all is tight and secure, hope this helps!i'll give it a go bud. yeah i have recently had coilovers put on, i have checked them but it might be worth having a double check to make sure!cheers Quote
theminiguru Posted January 10, 2011 Author Posted January 10, 2011 cv boot could be gonei had a cv joint go not that long ago and its a different sound...its only when i steer and i hit a slight bump or low curb it clunks!thanks Quote
ryan lang Posted January 10, 2011 Posted January 10, 2011 my coilies do it too, tighten the bottom ring, not the 2 that are under the spring but the 3rd 1 at the bottom of the thread parts of the shock Quote
