Josh@TunerLifestyle Posted January 23, 2011 Share Posted January 23, 2011 hi guys today i was driving my car and it felt strange... i was in 2nd gear then put my foot down and the revs picked rite up but not much go at all? dose this mean the cluch is slipping? its only when i floor it , it happens but when i drive it normaly its okay?just need some advice as i cant afford to change my cluck for another month :/ recon it will be ok to drive normaly till then?cheers josh Quote Link to post Share on other sites
Asad Posted January 23, 2011 Share Posted January 23, 2011 off boost and you`ll be fine, dont rev it too high either Quote Link to post Share on other sites
greasemonkeyspb Posted January 23, 2011 Share Posted January 23, 2011 yeah josh should be fine to drive but as said above try to not drive on boost as it will kill the clutch off fully lolgenerally when it slips it can last weeks on careful driving so if your careful you should be ok Quote Link to post Share on other sites
lew777 Posted January 23, 2011 Share Posted January 23, 2011 Try pull of in 2nd or 4th cant quite remember which but if you pull of the clutch is fooked Quote Link to post Share on other sites
greasemonkeyspb Posted January 23, 2011 Share Posted January 23, 2011 yeah keep car stationary with handbrake put car in third or fourth use right foot heel and toe on brake and accelerator pedal at same time raise the revs and apply pressure on brake pedal and ease the foot off the clutch (left foot) if engine stalls then clutch not slipping bad but if it doesnt change the the clutch is fooked Quote Link to post Share on other sites
Josh@TunerLifestyle Posted January 23, 2011 Author Share Posted January 23, 2011 il give that ago mate cheers! Quote Link to post Share on other sites
Dean @RW-Developments Posted January 25, 2011 Share Posted January 25, 2011 must admit when you said the other day it did feel a bit weird?? Quote Link to post Share on other sites
yaristurbo Posted January 26, 2011 Share Posted January 26, 2011 wont be long now till its smoked mine was same, it will keep slipping lower and lower in the rev range Quote Link to post Share on other sites
tersplat Posted January 26, 2011 Share Posted January 26, 2011 That all depends on how you drive it. even driving it very conservatively, it wont last forever, because it is going to slip some no matter what, but the easier you drive it, and the less you slip it when stopped, the longer it will last. Quote Link to post Share on other sites
