Preston Posted January 26, 2011 Share Posted January 26, 2011 yo.. i brought a cheap crap stainless steel manifold off of ebay. for £100 i knew it wouldnt be great as it was so cheap but its been on the car 3 weeks done about 200miles and its cracked around 2 of the welds and the plate that bolts onto the head is warped like a banana . wil add pics (too dark to see atm) so would recomend to anyone to not buy this sh*t ! so need to get a new 1 on there quick ... was looking at race-tech what do you lot think of them any better or will they crack too?..... also thinking of a de-cat will i need to get it maped? or will it run ok on standard ecu? your feed back would be much appreciated http://www.race-tech.net/index.php?main_page=shopping_cart this is what im looking at .. poor credit card! thanks tom Quote Link to post Share on other sites
Kennedy Posted January 26, 2011 Share Posted January 26, 2011 Ebay manifolds are failRace Tech manifolds are winOf course there is always a possibility they will crack but race tech manifolds are well made.Get it braced if you are concerned. Quote Link to post Share on other sites
ktl Posted January 26, 2011 Share Posted January 26, 2011 lol if you knew it was crap then why buy it in the first place ? you also got wepr and zisco if you want 100%products. Quote Link to post Share on other sites
Socks Posted January 26, 2011 Share Posted January 26, 2011 dont think ive ever seen or heard of a racetech manifold cracking...even if 1 did im sure ricky would fix it for u! :/i had a ebya manifold and it was a failure in less miles then that! Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 well i thought it would last longer than it did lol ... cheers for the info my credit cards about to get abused!.. what about the decat will i need a remap ? or will it run ok ? Quote Link to post Share on other sites
jpgt Posted January 26, 2011 Share Posted January 26, 2011 My Mani has just cracked on mine sounds like a similar one to yours had it a few months and cracked though the middle. Just ordered a Racetech Mani but apparently 4-6 week wait for them, been recommended by everyone so got to be good. Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 4-6 weeks ? man im impatiant .. my car sounds like a bag of shit dont know if i can wait that long .. any feedback on decats? Quote Link to post Share on other sites
ktl Posted January 26, 2011 Share Posted January 26, 2011 you wont need a remap, whats your spec of your car ? Quote Link to post Share on other sites
Sanchez Posted January 26, 2011 Share Posted January 26, 2011 lol at how many of these threads pop up Quote Link to post Share on other sites
chris H Posted January 26, 2011 Share Posted January 26, 2011 avoid the stainless mani's mate, they can't take the heat, the cheap ones and shite stainless and absorb nitrogen which makes them brittle and a twat to weld up again, go for a mild steel imo. Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 spec is as follows fmic big 1 ss maniblits nur spec rhks ssqv bovmonster air filter reclocationngk irridium plugslots of shiney bits enkei p1 wheels tein s springsremoved air con Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 avoid the stainless mani's mate, they can't take the heat, the cheap ones and shite stainless and absorb nitrogen which makes them brittle and a twat to weld up again, go for a mild steel imo.any recomendations of which mild steel 1 ? and wherr to get them ? Quote Link to post Share on other sites
StarletMad Posted January 26, 2011 Share Posted January 26, 2011 Cant fault my S/S TD04 Mani... Has worked a treat!! Quote Link to post Share on other sites
ktl Posted January 26, 2011 Share Posted January 26, 2011 u wont need a remap with a decat then. you wont need 1 untill you go different ecu. all you do is when you go over 0.85 bar i.e FCD + fpr or a differene ecu take it to the tuners to make sure shes fuelingright Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 u wont need a remap with a decat then. you wont need 1 untill you go different ecu. all you do is when you go over 0.85 bar i.e FCD + fpr or a differene ecu take it to the tuners to make sure shes fuelingrightHUH? . .fuel cut defence?.. is that what stops the enigine light commin on when drop it into 4th when your doin about 100? lol i can do all the mechanical shit to my car but when it comes to electrics i havent got a clue! please explain lol Quote Link to post Share on other sites
ktl Posted January 26, 2011 Share Posted January 26, 2011 yes fuel cut, when you over boost "around 0.8bar"... you either need a fuel cut def to remove it but then you need a rising rate fuel presure to add more fuel because the FCD makes the car lean (less fuel)....or just buy an Emanage, or a piggyback ecu then goto someone to map it. job done. so you dont need to worry for now untill you go over the fuel cut 0.8bar. hope this helps Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 mine overboosts already Quote Link to post Share on other sites
ktl Posted January 26, 2011 Share Posted January 26, 2011 does it fuel cut then ? Quote Link to post Share on other sites
Preston Posted January 26, 2011 Author Share Posted January 26, 2011 yeh engine light comes on and only half boosts? untill you turn it off and on again.??? Quote Link to post Share on other sites
