right yesterday i hit a pot hole and its burst my shock and put a slight buckle in my alloy, also the car just doesnt feel like its running right, turbo seems to kick in abit late and just doesnt feel like it should do, i have been out of work for a few months now and im tottally skint and i mean skint! so i cant afford to repair this so is it worth selling the car? and i will not let it go for less then 4k as i spent thousands on it, or am i best of just breaking? but if then i get a phone call with some work then i wont have a car for a few weeks if i do break. have no idea what to do and just wish i had neer bothered to buy a starlet!
If you managed to burst a shock you must have really whacked it, is it making full boost. Probably a leak caused by the whack, check that first. I wouldnt rush into selling your starlet I have noticed as of late there are alot of unsold starlets about at the moment, i have been looking for one and there seems to be loads of them, especially people who have modded them and are asking between 3-4k, from what i have seen hardly any of them are selling!
Noticed also alot of people are losing their jobs too, tough times mate. Breaking i guess would be the only sure way to do it, but that takes months!
i agree with liam, hold on to it!
liam i would like to keep it but i cant actually afford to, i have been driving it since i hit it and its fine just makes a horrible knocking noise, i cant put petrol in it to go job hunting or anything, and to be honest i dont actually no if i want to keep it, have thrown money at it and got nothing out of it
yeah i no
im just sick of my car
its a total heap of shit and i dont want to sell it onto someone because i will feel like i ripped them off
the engine is perfect but nothing else
will be coming down to brands hatch in just over a mounth if u can hang on i will com and sort it got a few turbos here. is thr blue smoke. and are u still loosing oil. i found a problem with the flexi turbo oil feeds.
no blue smoke and the oil level is still at the max but there is defiantly an oil leak
im going to get the timing checked this week because i think thats whats causing the turbo to kick in late
the car is just really laggy
had the probblem a while
it still hits 1bar of boost but i had to winde the actuator really far to get 1bar
should i take the hybrid off and fit my old turbo then have the timing checked?
the problem is if u wind in the actuator u will cause the turbo to increase its rpm this will cause turbo failiar. plus it might cause blade failiar, which might reach the engine. also u will find the intake charge increase in temp the fast the turbo spins as the turbo becames ineffiecent. yes check your waste gate for crack and your impeller for lost fins. also check the gate is nice and free and actuator does not leak.
let us know ollie wat u find, check for booste leaks with a squirty bottle full of washing up liquid. jack the front wheels off the ground and rev engine in thrid. this will put the engine under load and will not allow the engine to free rev which will allow booste presure to build better. and show up leaks better, take the wheels off for safety.
it wasnt a big pot hole tho, just have so many around my way its unreal so hitting 20a day is just killing the car, the exhaust is loose aswell and rattle around like a bitch on the rear axle
Still, go take pictures of it and pictures of the damaged caused. Google it, people have won cases left right centre.
