basically as im sure most of you are aware got a few issues with my car, the main issue anoying me at the moment that really should get sorted is a oil leak from where the gearbox meets the engine, im sure this is the main crank seal? please correct me if im wrong
and i no to change this seal you have to take the gearbox out, clutch and flywheel off aswell but im no mehcanic by anymeans so is there anyone in the local area of surrey or kent ect that would be willing to lend a hand for a day to help me sort this as im out of work and have no money to pay a mechanic to do this as it wont come cheap
i will drive to your place or you come to mine depending whats easiest and also i only have basic tools
any help would be gratly appreciated
thanks
ollie
I looked to have a oil leak in same place, its rear main crank seal £50 quid from toyota too! Whipped box and everything off dry as a bone inside, changed crank seal anyway as it cost me so much!
It was my sump that was leaking. So change your sump seal first.
I'm happy to help you mate!
Same as me. I'm no mechanic by a long shot but I will give my drive up for the day to help you out!
Plus you never text me if you wanted to borrow the suspension!
Count me in mate, may even be able to get an engine crane to help out
thats brillant cheers
i was going to text you yesterday but i took my car to bits and got fedup so left it in bits and should probably put some stuff back on it tomorrow
im thinking of doing the engine mounts aswell but dont no how hard they are to do
best thing to do is re seal the sump to start with clean it all off and run it and if u still have a leak then takle the rear crank seal mate because i firstly just buned silicone around the sump and still had the leak so i changed the rear seal and it stopped. its easier to re seal the sump than do the crank seal so il start by doing that and take it step at a time hope this helps
yer drop the sump make sure both surfaces are clean then put the new gasket on and can use selant to and then bolt it back up evenly and to do the main seal the box has to come out clutch and fly wheel mate
Engine mounts are a piece off piss once the block is out! literally a couple of bolts and you are away!
Not had the luxury of doing the gearbox yet, just need to connect mine up!
Takes a couple of hours if thats all you need to do.
Take the engine and jack it up to take the weight off the mounts. then just change em!
I had the whole engine out when I did it, I think you can get away without doing that though.
Would double check though!
Just support tge weight of the engine and drop of the mounts and change em one at a time, they are fairly easy to swap tbh, and id start with the sump too, taking the fly off for the crank seal will be the hardest part! We had to use an airgun on the bolts as they ar tourqed up high and locktighted when installed so are a biach to get out :o
If the oil leak is bad you may want to consider a new clutch when you do the box and also clean the fly realy well, as oil will contaminate the friction pads on the cluch disc and effect the disc. just make sure you check it all over well. Thats only if it doesnt turn out to be the sump as that may well cure your issue anyhow :o
