Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 had my engine fitted yesterday picked it up from garage on way home temp gauge went to red hot had to drive it for 5 min to get it off motorway water pump had leaked all the water from rad,it was smoking before when i let off boost now when i pull up to lights you cant see the car with white smoke has the car over heating done the steam seals or could it be down to the turbo,the turbo was fitted to car that put conrod threw the block with lots off shaft play,on first start up dont smoke at all till you take it for drive,im hoping its the turbo has i have spent over £1000 quid to get the car running Quote
Whitegv Posted January 31, 2011 Posted January 31, 2011 headgasket if its overheated badly mate. could have warped the head so that would also need a skim to make sure its flat again Quote
Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 got no water in the oil,no misfire runs and sounds 100% just smoke's really bad to the point you cant see the car when you pull up Quote
Whitegv Posted January 31, 2011 Posted January 31, 2011 i duuno then mate. my car smokes a lot as well a white smoke with a blue tint to it. my mechanic reckons its more likely to be turbo seals than anything else, but also mentioned valve stem seals. spose youi could check the turbo by taking off some intercooler piping and see if its full of shit? Quote
Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 ^^ thats what i have white smoke mixed with blue but when i say loads off smoke you cant see the car its that bad,turbo does have loads off shaft play Quote
Arahan Posted January 31, 2011 Posted January 31, 2011 If it doesnt smoke till its warm then sounds like the turbo, but obviously got other problems if the waters gone But after knowing where you took it to have work done, I can't say I'm surprised... Quote
Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 ^^ cool going change it tonight thanks to miib14 Quote
_shaun_ Posted January 31, 2011 Posted January 31, 2011 gonna sound realy stupid but i bought a golf as a run round ages ago and it did this when i got it turned out prev owner had put to much oil in it like a good half inch over max blink:drained it and it was fine after Quote
Arahan Posted January 31, 2011 Posted January 31, 2011 When you coming down for those harnesses anyway Paul me old mukka? Quote
Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 ^^ i was going take them yesterday but maxed my card out fixed twat off glanza you will call see you when i drop engine off to luke probz tomo Quote
Guest cheshireglanza Posted January 31, 2011 Posted January 31, 2011 so people think change turbo Quote
miib14 Posted January 31, 2011 Posted January 31, 2011 ^^ cool going change it tonight thanks to miib14no probz mate.. helping each other out... you get to check if your turbo knackered and i get to check if mine works fine or not Quote
Markoos Posted February 1, 2011 Posted February 1, 2011 Maybe its got something to do with the fact that nick didnt plug the rad fan back in when he did your engine............. ;) Quote
Guest cheshireglanza Posted February 1, 2011 Posted February 1, 2011 ^^ thats not got any thing do with it you clown lol,looks like turbo has shit it self exhaust side covered in oil Quote
Markoos Posted February 1, 2011 Posted February 1, 2011 ^^ thats not got any thing do with it you clown lol,looks like turbo has shit it self exhaust side covered in oilover heating engine........ rad not plugged in.......... hmmmmmm ;) Quote
nazzurro19 Posted February 1, 2011 Posted February 1, 2011 ^^ thats not got any thing do with it you clown lol,looks like turbo has shit it self exhaust side covered in oilsorry to spam but payment sent for wind deflectors dude ;) cheers Quote
Guest cheshireglanza Posted February 1, 2011 Posted February 1, 2011 ^^ cheers matemark a car should not need the fan doing 70 on motorway ;) Quote
aaddzz123 Posted February 14, 2011 Posted February 14, 2011 I'd deffinately do a compression test mate. If the compression is fine all round, it's not using A LOT of oil or water but smokes, I'd try the turbo... My engine has problems atm, same kinda thing really but compression in my 1st cylinder is less than half... I think it's the head gasket but could be a bent valve or cracked piston or ring... I won't know till it's in bits!Good luck mate. Do a compression test!! Quote
Nanglebadger Posted February 14, 2011 Posted February 14, 2011 ^^ cheers matemark a car should not need the fan doing 70 on motorway trading on a trading ban Paul??Certainly looks like it.Phil. Quote
Mattb504 Posted February 17, 2011 Posted February 17, 2011 Alright mate,Mine was smoking really bad aswell! only after i booted it loads of white an blue smoke. i changed the turbo on the week-end and now all is ok! (touch wood) i havnt had any smoke at all. So most proberly that to be honest mate. Quote
