Janus Posted February 6, 2011 Posted February 6, 2011 Hello all. My heating is merely luke warm. Does anyone know how to fix this? Not sure if its the thermostat or somnething elsecheers Quote
chris H Posted February 6, 2011 Posted February 6, 2011 from cold take your rad cap off, turn your heater to the hottest setting, start the engine and top up the rad, let it warm up with the rad cap off and that should expell any air in the system mate Quote
Janus Posted February 6, 2011 Author Posted February 6, 2011 from cold take your rad cap off, turn your heater to the hottest setting, start the engine and top up the rad, let it warm up with the rad cap off and that should expell any air in the system mateCheers. I changed the coolant at the weekend and it seemed a touch warmer. Just not sure if the thermostat is duff Quote
StarletMad Posted February 6, 2011 Posted February 6, 2011 Get an air line and a rag and blow the matrix out... My "Heating" was cold and just by doing Im cooooooooooookkkkinggg! Quote
Janus Posted February 6, 2011 Author Posted February 6, 2011 Get an air line and a rag and blow the matrix out... My "Heating" was cold and just by doing Im cooooooooooookkkkinggg!How do you do that? Quote
daz gt turbz Posted February 6, 2011 Posted February 6, 2011 what does the engine temp do when its running? does it get warm or always stay cold? Quote
micky boy Posted February 6, 2011 Posted February 6, 2011 Most probably the heater matrix is fucked, unfortunately your dash has to come out to get to it. Quote
StarletMad Posted February 7, 2011 Posted February 7, 2011 Take both pipes off in the engine bay put the air line in and the rag packed around it and fire away The rag just gives it more pressure as all the air is then forced forward and doesnt come backwards Quote
Janus Posted February 7, 2011 Author Posted February 7, 2011 what does the engine temp do when its running? does it get warm or always stay cold?It gets warmm gradually but sometimes goes down. It goes up when sat in neutral but sometimes goes down when im just doing general driving. Quote
HansonManson Posted February 23, 2011 Posted February 23, 2011 check the thermostat i just bout new one for mine as its jammed Quote
Josh@TunerLifestyle Posted February 23, 2011 Posted February 23, 2011 Sounds like the thermo dude, get it changed Quote
daveEP82 Posted February 23, 2011 Posted February 23, 2011 either that or have you had coolant in her over the winter maybe lost some impellers out of the water pump? Quote
