madmax_926 Posted February 9, 2011 Posted February 9, 2011 Hi people hopefully someone could help me out?My glanza v is sitting pretty low and am having a problem with it only on full lock. To get an idea of ride height pic is below:Basically if i put the car on full lock there is no noises, the noise doesn't happen until i pull away on full lock, it sounds like a massive " ting" sound as you have hit a piece of metal with a hammer? Sounds almost like something shears a bolt and comes from around the suspension strut area? Im running bc coilovers and a whiteline farb but even before i changed the rollbar i had the same problem. Gearbox mounts have been replaced, driveshafts look good + plus i raised the car up high with jack and started car and checked if there were any clearance issues all seemed well? Could the car be to low and stress the driveshafts on full lock? can you recommend me anything to check? thanks all max Quote
lukerobz Posted February 9, 2011 Posted February 9, 2011 i would say it was your cv joint mate dont se how being lower it would make it knock thou maybe its just on its way out ??? Quote
madmax_926 Posted February 9, 2011 Author Posted February 9, 2011 they look mint like the boots and that look fine? i dunno? probably is that as its well common, still unsure is this a costly repair? and would the garage not have notcided a problem with this when chnaging my clutch as i had this done recently i wa shaving the same problem beofre and its doing this turning left or right? Quote
madmax_926 Posted February 9, 2011 Author Posted February 9, 2011 also its not like a knoc knock knock its just one single " kaa- ting" sound if you catch my drift Quote
TrisK Posted February 9, 2011 Posted February 9, 2011 also its not like a knoc knock knock its just one single " kaa- ting" sound if you catch my drifti have a similar thing as im braking to a stop, and my car is pretty low on tiens Quote
lukerobz Posted February 9, 2011 Posted February 9, 2011 also its not like a knoc knock knock its just one single " kaa- ting" sound if you catch my drifthmm no idea then buddy hope u get it sorted Quote
madmax_926 Posted February 9, 2011 Author Posted February 9, 2011 hmm no idea then buddy hope u get it sortedcheers for advice though bro Quote
madmax_926 Posted February 9, 2011 Author Posted February 9, 2011 bump plz any thing else to check guys Quote
Craig_N Posted February 9, 2011 Posted February 9, 2011 Try adjusting the collies so the car is a little higher and see if that works worth a try Quote
madmax_926 Posted February 10, 2011 Author Posted February 10, 2011 true bean im proper lazy i need to do this anyway as my exhaust is catching on the car park post. is there guide to setting coilovers as im a complete "joey" when it comes to using tools etc, i know its fairly easy. I have seen glanzas lower than my car and they dont seem to have the same problem?thanks for reply Quote
starlet786 Posted February 10, 2011 Posted February 10, 2011 its your cv joint mate i had same problem and it was that...and my allignment was out aswell Quote
madmax_926 Posted February 10, 2011 Author Posted February 10, 2011 its doin it on full lock either way and sound will come from either side depending on which way im turning. would this not have been checked during a clutch change? and it makes me think its not cv joint as it both sides and i have no knocking or anything its one single "kaaa- ting" sound? Quote
Daniel. Posted February 10, 2011 Posted February 10, 2011 my does the exact same noise, its defiantly the springs, the ting sound that is, myne knocks a little but i think its my cv joint, the ting sound is only when im parking, just dont know how its doing it! Quote
1987glanza Posted February 10, 2011 Posted February 10, 2011 yeah deffinitly your cv joint, if i had a £ for every one i changed due to the car being to lowered to much i would be a very rich man...lol Quote
madmax_926 Posted February 11, 2011 Author Posted February 11, 2011 my does the exact same noise, its defiantly the springs, the ting sound that is, myne knocks a little but i think its my cv joint, the ting sound is only when im parking, just dont know how its doing it!yeah its 100% the springs that ting it sounds like it comes from the coilovers Quote
madmax_926 Posted February 11, 2011 Author Posted February 11, 2011 my does the exact same noise, its defiantly the springs, the ting sound that is, myne knocks a little but i think its my cv joint, the ting sound is only when im parking, just dont know how its doing it!same here mate that ting is coming from the coilovers and sound slike spring? its doing my head in my cvs are fine in what is causing the coilovers to do that? Quote
