The Toffinator Posted February 10, 2011 Posted February 10, 2011 I have some GT/GLanza calipers sat here that have been refurbed. i want them on my N/A which doesnt have abs, i am aware i will need the pads and discs, but do the calipers bolt straight on?And also, which pads and discs are the ones i want if the calipers bolt straight on?Thanks! Quote
micky boy Posted February 17, 2011 Posted February 17, 2011 Arnt the front calipers the same on an N/A?.. im sure all thats diffrent is the Glanza/GT use bigger disks/pads could be rong though Edit.. also if you want some front disks and pads i've got some here...the pads have done about 1000k and disks have done abit more Quote
The Toffinator Posted February 17, 2011 Author Posted February 17, 2011 Is that right? will have to check the part numbers on my calipers, or it may be the same caliper, but with a different caliper bracket. will see. and dude that would be perfect, Pmed you Quote
The Toffinator Posted February 25, 2011 Author Posted February 25, 2011 Sorted. they fit on fine bar the dust shield, which i just trimmed back. mountings on the hub are identical, and my calipers where glanza ones.Discs are a fair bit bigger, pads are the same size. Quote
Russleh Posted February 25, 2011 Posted February 25, 2011 just comepare the calipers and if they are the same size there the same ones. some n/a's came with smaller calipers although i dunno which ones. if you want to see then have a look for g's conversion ( streetracer_starlet ) the build thread because he done the upgrade on the sleeper i think Quote
rob_bower Posted February 25, 2011 Posted February 25, 2011 It's just the carriers that are different from what I recall! Quote
