boost problems after new RB CT9 fitted
hey guys,
wonder if anyone could shed some light on what i can do to raise me boost pressure.
i fitted a new RB CT9 turbo not long ago, along with a manifold,induction kit etc., and putting the decat on today but it will only boost top a max of 0.24 bar according to the boost gauge and turbo timer.
running great just not boosting as she used to :thumbsup:
i have a japspeed manual boost controller i can fit but have left that off as i am not sure if i want to fit it, heard the manual BC's aint great but cant afford a EBC just yet.
any ideas on why its boosting so low? could it be on a default setting or anything or more lightly to be mechanical?
also what bar could i reliably run at with a blitz induction/ dual turbo timer, zisco compact mani, RB CT9, japspeed exhaust, autobahn hoses, rocker breather soon to be catch can, no fmic though so i am not sure what to run it at.
any suggestions would be very helpful!
Thanks Guys
Parko
cool i wilol check the pipes but think there all fine.
yeah i am still using the standard actuator on there. what actuator did you get? mines not the hubrid though just has a bored out wastegate
cheers
cheers
cheers
The standered actuator will not be strong enough to hold the penny over wastegate as its now bigger, i got a HKS actuator an jus adjusted it up till it started holding boost better...
sweet thanks alot mate thats what i will get done then
the stock actuator will just allow the wastegate to open matey... get yourself a HKS jobbie and remember it wants to be tight on the connector so u have to put a bit of pull on it to et it on and go from there :)
dont let it worry u, easy fix :)
Cheers matey :)
