ryan lang Posted February 17, 2011 Posted February 17, 2011 what remote? for your cd player, because that looks like the live wire i used for my sub and ampit probably runs through to the boot, because those are wires for 6x9s also. check if you've got a chunky wire coming from your battery to the firewall because its most likely for a sub or amp Quote
wssoR Posted February 17, 2011 Author Posted February 17, 2011 I'm fitting a sub now mate, I'm just checking that I attachthe remote wire to this light blue one Quote
Raz Posted February 17, 2011 Posted February 17, 2011 The wire SHOULD say switched +12v or something. Quote
Asad Posted February 17, 2011 Posted February 17, 2011 Yes its the blue one, iirc tells the amp wen to turn on Quote
TrisK Posted February 17, 2011 Posted February 17, 2011 Yes its the blue one, iirc tells the amp wen to turn onThisit will come off the head unit.make sure you run power + remote down one side, and rca/speaker cable down the other or you will get interferance (a whine that rises and falls with revs) Quote
