wssoR Posted February 17, 2011 Share Posted February 17, 2011 The light blue one? Quote Link to post Share on other sites
ryan lang Posted February 17, 2011 Share Posted February 17, 2011 what remote? for your cd player, because that looks like the live wire i used for my sub and ampit probably runs through to the boot, because those are wires for 6x9s also. check if you've got a chunky wire coming from your battery to the firewall because its most likely for a sub or amp Quote Link to post Share on other sites
wssoR Posted February 17, 2011 Author Share Posted February 17, 2011 I'm fitting a sub now mate, I'm just checking that I attachthe remote wire to this light blue one Quote Link to post Share on other sites
Raz Posted February 17, 2011 Share Posted February 17, 2011 The wire SHOULD say switched +12v or something. Quote Link to post Share on other sites
Asad Posted February 17, 2011 Share Posted February 17, 2011 Yes its the blue one, iirc tells the amp wen to turn on Quote Link to post Share on other sites
TrisK Posted February 17, 2011 Share Posted February 17, 2011 Asad_EP5DR said: Yes its the blue one, iirc tells the amp wen to turn onThisit will come off the head unit.make sure you run power + remote down one side, and rca/speaker cable down the other or you will get interferance (a whine that rises and falls with revs) Quote Link to post Share on other sites
