ep91_glanza Posted February 17, 2011 Posted February 17, 2011 can anyone please tell me whats wrong.. i bought a clutch and was for an ep91 and when i came to fit it the holes didnt line up to the flywheel,the clutch is too big? my car was converted from a auto to a manual before i bought it does that have anything to do with the sizes??cheers karl Quote
lukEp Posted February 17, 2011 Posted February 17, 2011 you bought a turbo clutch and have an N/A flywheel the N/A flywheel is smaller than the turbo which i can only think it has a n/a gearbox to Quote
yaristurbo Posted February 17, 2011 Posted February 17, 2011 yeh that sounds like the problem, i have a turbo flywheel if you want it?? Quote
ep91_glanza Posted February 17, 2011 Author Posted February 17, 2011 yeh that sounds like the problem, i have a turbo flywheel if you want it??how much u want for it Quote
ep91_glanza Posted February 17, 2011 Author Posted February 17, 2011 how much u want for itwill i need some different bolts aswell cause someone said they wer longer bolts r somthing Quote
ep91_glanza Posted February 17, 2011 Author Posted February 17, 2011 nope there the sameis the flywheel actually bigger or is it just the grommits on the side that are different?? Quote
lukEp Posted February 17, 2011 Posted February 17, 2011 the flywheel is the same size the dowel are differently spaced to take the bigger clutch Quote
ep91_glanza Posted February 17, 2011 Author Posted February 17, 2011 the flywheel is the same size the dowel are differently spaced to take the bigger clutchoh good because that would be a t**t with the starter motor and that cheers Quote
