Josh@TunerLifestyle Posted February 24, 2011 Author Posted February 24, 2011 Only comes on when the cars at full temp when im over 3000rpm, I've tested it like going along at 2500rpm for ages and its fine but if i just go over 3000 it comes on, really strange lol ill read the codes tommorrow Quote
Josh@TunerLifestyle Posted February 25, 2011 Author Posted February 25, 2011 Falt codes! 34 turbo pressure signal, fuel cut right?42 vss? Quote
Josh@TunerLifestyle Posted February 25, 2011 Author Posted February 25, 2011 any other ideas people? what other things come under the code 42 as well as the coolent temp sensor?really would be a big help!cheers josh Quote
micky boy Posted February 25, 2011 Posted February 25, 2011 Dose this help at allhttp://www.toyotanation.com/forum/showthread.php?t=308614Maybe this lolhttp://www.antiguastreetz.com/forums/showthread.php?t=394 Quote
Josh@TunerLifestyle Posted February 25, 2011 Author Posted February 25, 2011 yehh i found that chart on here lolas it says VSS no sigal, what is vss? is it just the coolent temp sensor or is there more to it? Quote
micky boy Posted February 25, 2011 Posted February 25, 2011 Hmm not sure what VSS means to be honest it probably stands for something silly lolThe only thing you can do is try someone elses sensor thats working..if you live near Toyota then have a pop in and ask one of the lads what VSS stands for they might be able to help more then i can lol Quote
Josh@TunerLifestyle Posted February 25, 2011 Author Posted February 25, 2011 cheers mikey never thaught of popping into toyota Quote
daz gt turbz Posted February 25, 2011 Posted February 25, 2011 VSS is variable speed sensor but i dont know exactly what it is Quote
daz gt turbz Posted February 25, 2011 Posted February 25, 2011 cheers mikey never thaught of popping into toyota my local toyota is usless, when i 1st got my gt i took it there for a full service, went to pick it up and they said they couldnt change the oil as they carnt see a filter! 1 of them chirped up and said"i dont think they have oil filters"! i got them to pull it back on the ramp and i had to show them where it was! Quote
Josh@TunerLifestyle Posted February 25, 2011 Author Posted February 25, 2011 if you read code 42 where it says VSS it basicly says my symptoms lol all i need to do it find how to sort it lol Quote
Josh@TunerLifestyle Posted March 15, 2011 Author Posted March 15, 2011 Guys I've changed the sensor again but the lights still coming onn!! What else could i do?????????? Quote
Ricky@Race-Tech Posted March 15, 2011 Posted March 15, 2011 Guys I've changed the sensor again but the lights still coming onn!! What else could i do??????????What sensor did you change? VSS or CTS again? (coolant temp sensor) Quote
Josh@TunerLifestyle Posted March 15, 2011 Author Posted March 15, 2011 Cts mate i dont know where the vss is, looks like or get one from lol Quote
micky boy Posted March 15, 2011 Posted March 15, 2011 So shes defo not over boosting?..Dose the light only come on when you give it big licks? just a ct9s at full pelt at 2500/3000rpm and sounds more like fuel cut to me lol Quote
Josh@TunerLifestyle Posted March 15, 2011 Author Posted March 15, 2011 its defo not over boosting mate, i drive in 5th gear about 60mph just over 3000 rpm and its hardly boosting, i can hit fuel cut when i boot it but thats when i boot it lolthe vss is the vehicle speed sensor , jus reading a thread on tgtt and it says its a sensor or a wire somewhere,just need more info on it :/ Quote
micky boy Posted March 15, 2011 Posted March 15, 2011 Hmm i wouldnt mind knowing where this vss is aswell...Hope you get it sorted mate things like this piss me off lol just not knowing what it is haha Quote
Josh@TunerLifestyle Posted March 15, 2011 Author Posted March 15, 2011 found some more info and says an orange wire at the passanger side rear of the car near the wheel bearing? hmmm when i get a chance im going to have a look! Quote
