ep91_glanza Posted February 25, 2011 Posted February 25, 2011 Hi just a little help please i need a gearbox seal does any one know where to get them on the internet and how much or do i need to go to toyota for them cheers Quote
ToyotaTech15 Posted February 25, 2011 Posted February 25, 2011 Hi just a little help please i need a gearbox seal does any one know where to get them on the internet and how much or do i need to go to toyota for them cheersHi,What seals is it that you need?Im not sure if there are any online places for seals, If you pm what ones you are after ill be at work tomorow and ill get a delivered priced for you.Gary Quote
ep91_glanza Posted February 25, 2011 Author Posted February 25, 2011 Hi,What seals is it that you need?Im not sure if there are any online places for seals, If you pm what ones you are after ill be at work tomorow and ill get a delivered priced for you.Garyyeah if you can mate its the seal on the gearbox where the driveshafts go in Quote
ToyotaTech15 Posted February 25, 2011 Posted February 25, 2011 Hi, No problem, going by your avatar im guessing its a 96 V you have?Thanks Gary Quote
ep91_glanza Posted February 25, 2011 Author Posted February 25, 2011 Hi, No problem, going by your avatar im guessing its a 96 V you have?Thanks Garyyeah mate cheers for the help just pm me a price or text/ring. Karl 07837014409 cheers Quote
Torquelee Posted July 16, 2012 Posted July 16, 2012 Hi guys are the driveshaft seals which enter the gearbox passenger side easy to fit? Mine has gone and is leaking alot of fluid I've ordered a new one from Toyota and if it's easy I'll do it myself if anyone knows could you text me with fitting instructions? 07825392160 cheers nick Quote
aidanep71 Posted July 16, 2012 Posted July 16, 2012 very easy to fit pull the shaft out of the box pull out the old seal with a screw driver or something clean the box where the seal sits tap the new seal in with a big socket and hammer Quote
Torquelee Posted July 17, 2012 Posted July 17, 2012 Cheers buddy gonna do it tomorrow when I recieve the seal will let you know the outcome Quote
Flaminsam Posted July 18, 2012 Posted July 18, 2012 Piece of piss to change bud. I didn't even take my wheel off. Info the three 14mm bolts off the bottom balljoint and using a lever bar pop the shaft out of the box. Fit new seal then use the wheel as a sort of sliding hammer to pop the shaft back in the box. Be careful when refitting the shaft though. There is a round spring that sits in the seal, if you pop this off the seal will leak again. Quote
Torquelee Posted July 18, 2012 Posted July 18, 2012 Wow and it's that easy is it? I took the seal out my other box and it was a s**t to get out :/ I got some new ones from Toyota but sadly the passenger one is wrong so now gotta wait for the right one which is gonna take 3 days so that's another 3 days of just looking at my glanza and not driving it which is really annoying Quote
Flaminsam Posted July 18, 2012 Posted July 18, 2012 it is quite easy to do really. took me literally half a hour to do. maybe with me being a mechanic had something to do with it? Quote
Torquelee Posted July 19, 2012 Posted July 19, 2012 I can't get the seal in all the way and it must be slightly wonky as its a mil or too off flush with box Quote
Torquelee Posted July 19, 2012 Posted July 19, 2012 Well I've done it dudes the seal I think is slightly off set but I couldn't get it any better fingers crossed it'll be ok thank you for your help Quote
