car feels like shite !!!!!
hi guys, having a few problems with my GT, over the last few months its not been feeling as good to drive as it did when i 1st had it, its had new plugs, leads, oil and oil filter wich helped a little bit but now it just feels the same again, the problems i'm having are -
juddering when pulling off, allmost feels like the car looses all its power and nearly stalls
idle speed is all to shit, some times on a warm start up idles at 500 prm
really late boost, comes on full boost at about 4500 rpm on a ct9 with air filter re location, standard mani and decat
and i've been told that its running ritch (only by my mate who knows a small amount)
the mods i have are -
fmic
air filter relocated to the grill
decat and ss exhaust
hks bov
uprated fuel pump
i hav allso noticed the car has an aftermarket ecu left on it by the preveous owner, it dosent hit fuel cut till 1.0 bar and goes well past the 180kmh on the clock :) i was going to try an unplug the ecu and see if i can run it on the standard one ??????
any info would be great cheers guys !
As above, if you are running 1.0bar on the standard maifold you may have caused some problems to your engine (depending how long you've ran the car like this for). The 3rd runner is really restrictive and iirc the 2nd runner is fairly restrictive as well..
Try to find out what ECU it has, are you sure it doesn't just have a FCD fitted alone?
Also check for boost leaks!
not sure what ecu it is, just a plain silver box that sits under the standars one :) definatley not got a fcd fitted to it.
will be going in to the garage soon to have a new clutch fitted and maybe my td04 kit, so i'll get them to do a compression test, i just dont want to fit the td04 kit to it if its not running as it should be
