well car should be getting maped next week but not totaly sure on what boost to go for 1.2seems safe but few people seem to be running fair bit higher boost on stock internals.
whos running a td04 on stock internals and what your boost set to ? and how longs it been running that boost?
cheers shaun
cheers shaun
I did 1.2/3 for well over a year without a problem, then turned it up and did 1.4/5 without an issue including loads of 1/4 mile runs and a few track sessions.
Cars still going strong (stock now though)
Sparky is going to be doing similar on his, speak to yoru mapper though and see what they would be confident doing as if there not confident doing 1.3 then wouldnt go above that etc.
im running .6 atm, if i were keeping the car would probably not go any higher than a bar. maybe push to 1.2 when i fancy it. but not sure. alot of people seem to say its ok :)
As said I'll be running 1.4/1.5bar hopefully, Driver's car is my inspiration :p
Will be on a completely fresh engine though, with uprated gasket and ARP headbolts just in case the head decides it wants to rocket out of my bonnet at that boost lol
I would say you'd be safe at 1.2 bar though, its all down to the map at the end of the day
Driver's car is my inspiration B)
Awwww cheers :p
True though, 1.2 on a daily would be fine, map dependant ofcourse, if he cant map take it to someone who can !
Driver was on EMB I'll be on EMU and both externally gated, with the same RaceTech TD04 kit or at least his was very similar :p
ill be using an emu and the exact turbo kit driver used :p think ill stick with 1.2 then to be safe
Good to see my old kit being used well, be better at 1.5 though haha
