so im thinking about what turbo i want to switch for
il have a civic rad and air con gone, so ill have a lot of room
ill have a hdi fmic so will have lots of cooling.
so now i just need to think what turbo i want
i want something with quick spool. and would ideally like to run 1 bar or over.
most the roads ill be driving on are 40 limit. so i want something that will get me there quick for nipping around town (not waiting around for lag)
but also something that when i take it away will be happy on a motorway.
any suggestions?
TD04 is a very good setup, tried and tested!
quick spool but offering more power and torque then the stock ct9 blower...
ontop of that you can run them on 1bar on the stock engine safely, then if and when you forge the engine you can ramp the boost up to 1.6bar and get 250-270bhp...
ontop of all that, cheap units to buy and alot of the time stock rad friendly!
Race-Tech's kit is awesome... it comes with everything you need to fit one up!
http://www.race-tech.net/index.php?main_pa...amp;cPath=2_4_5
Wepr & Zisco also offer similar kits!
