1990timeismoney Posted March 23, 2011 Posted March 23, 2011 Hi is there any way to reset standard ecu Quote
1990timeismoney Posted March 23, 2011 Author Posted March 23, 2011 Just unplug your bat for 30 mins or so.hi thanks for the reply im also trying to get the air/fuel ratio back to normal and not sure how its running standard fpr but still a/f ratio on idle is 12.7 and when i accelarate it goes to 15.8any help would be greatthanks Quote
daz gt turbz Posted March 23, 2011 Posted March 23, 2011 just pull the efi fuse(under bonnet) out for 20 secs and put it back in, this resets the ecu. Quote
1990timeismoney Posted March 23, 2011 Author Posted March 23, 2011 just pull the efi fuse(under bonnet) out for 20 secs and put it back in, this resets the ecu. ok thanks very much shall i do that with the ignition on or of have u any idea why the air/fuel is not working rightthanks Quote
daz gt turbz Posted March 23, 2011 Posted March 23, 2011 do it with the keys on drivers seat! dont have a clue why its doing it mate but try that and see if it sorts it, if not we will have to dig deeper. Quote
1990timeismoney Posted March 23, 2011 Author Posted March 23, 2011 do it with the keys on drivers seat! dont have a clue why its doing it mate but try that and see if it sorts it, if not we will have to dig deeper.ok thanks ill try that and see what happensthanks Quote
1990timeismoney Posted March 23, 2011 Author Posted March 23, 2011 ok thanks ill try that and see what happensthankshi mate i tried that but still its the same air/fuel ratio on idle is 13.1 and when i acclerate it goes to 14.7 to 15 what is a good air/fuel ratio.thanks Quote
5T4R7ET N/A Posted March 23, 2011 Posted March 23, 2011 well when the car is fully warmed up the air/fuel ratio should be 14.7 on idle.when accelerating this will change, depending on if your on/off boost.cold start = 12.8:1 - 13.5:1acceleration = 11.6 - 12.3:1 deceleration = 16.2:1 - 17.6:1light acceleration = 13.7:1 - 15.2:1hope that helps Quote
