1990timeismoney Posted March 23, 2011 Share Posted March 23, 2011 Hi is there any way to reset standard ecu Quote Link to post Share on other sites
LukeSR Posted March 23, 2011 Share Posted March 23, 2011 Just unplug your bat for 30 mins or so. Quote Link to post Share on other sites
1990timeismoney Posted March 23, 2011 Author Share Posted March 23, 2011 LukeSR said: Just unplug your bat for 30 mins or so.hi thanks for the reply im also trying to get the air/fuel ratio back to normal and not sure how its running standard fpr but still a/f ratio on idle is 12.7 and when i accelarate it goes to 15.8any help would be greatthanks Quote Link to post Share on other sites
daz gt turbz Posted March 23, 2011 Share Posted March 23, 2011 just pull the efi fuse(under bonnet) out for 20 secs and put it back in, this resets the ecu. Quote Link to post Share on other sites
1990timeismoney Posted March 23, 2011 Author Share Posted March 23, 2011 daz gt turbz said: just pull the efi fuse(under bonnet) out for 20 secs and put it back in, this resets the ecu. ok thanks very much shall i do that with the ignition on or of have u any idea why the air/fuel is not working rightthanks Quote Link to post Share on other sites
daz gt turbz Posted March 23, 2011 Share Posted March 23, 2011 do it with the keys on drivers seat! dont have a clue why its doing it mate but try that and see if it sorts it, if not we will have to dig deeper. Quote Link to post Share on other sites
1990timeismoney Posted March 23, 2011 Author Share Posted March 23, 2011 daz gt turbz said: do it with the keys on drivers seat! dont have a clue why its doing it mate but try that and see if it sorts it, if not we will have to dig deeper.ok thanks ill try that and see what happensthanks Quote Link to post Share on other sites
1990timeismoney Posted March 23, 2011 Author Share Posted March 23, 2011 1990timeismoney said: ok thanks ill try that and see what happensthankshi mate i tried that but still its the same air/fuel ratio on idle is 13.1 and when i acclerate it goes to 14.7 to 15 what is a good air/fuel ratio.thanks Quote Link to post Share on other sites
5T4R7ET N/A Posted March 23, 2011 Share Posted March 23, 2011 well when the car is fully warmed up the air/fuel ratio should be 14.7 on idle.when accelerating this will change, depending on if your on/off boost.cold start = 12.8:1 - 13.5:1acceleration = 11.6 - 12.3:1 deceleration = 16.2:1 - 17.6:1light acceleration = 13.7:1 - 15.2:1hope that helps Quote Link to post Share on other sites
