sooo confused now what to do
right im confused n i cant make my mine up now, basically i have a wepr power up kit , short fmic , mani etc but after seeing steveGT thread with his crank oil seal going whilst running a hybrid has kinda put me off fitting one lol
my idea was nice short fmic and a nice hybrid turbo = little lag,lotsa power :thumbsup:
but then i was doing more research and now found out that a hybrid at 1.2/3 bar is the same as like a td04 at 0.8bar power wise but the td04 is a little laggy but how much laggy is it ?
so is it now worth me selling my power up kit n gettin a td04 kit ? cause the way i see it is , same power but less boost = less strain on engine
and is it true that you cant run 1bar on a td04 with a standard engine ? god im so confused on what to do !! oh and what ever option is best i will be running externally
cheers guys please help lol i wish i knew someone with a td04 so i could see the difference
my idea was nice short fmic and a nice hybrid turbo = little lag,lotsa power :o
There is several discussions on TGTT about this very subject dude! You can run a stock engine with higher than 1 bar of boost but it isnt advised because it normally doesnt last long! Steves was through a crank seal not being replaced, not just because he was running a hybrid. IMO its entirely down to personal preference. Ive got both turbos.. JUst gonna dabble a bit with both :thumbsup:
hmm i wana go hybrid for the fact that its like instant power n im pretty much complete now with the build
but then i know my engine isnt the strongest and i dont want it to die :thumbsup: lol
but then after running the strip last weekend maybe a td04 will give me a better time ?? hmm i like the hybrid route as its easier to install etc
ARGH!! ima have a look on tgtt
  nazzurro19 said:
hmm really ill check it out lol is fitting a td04 early though i dont get this whole lark with the oil and water return etc etc
You can buy a braided hose kit for them bud! Cant remember who on the forum does them but i remember seeing them
nah deans means a new manifold etc i contacted him as that was my original plan
dont the oil n water lines on the td04 need to be changed though ? i thought it had to be made to run 2 oil lines in/out instead of one being water or something
its the same as ct9 mate, 1 oil feed, 1 oil return and 2 water lines
You don't need water lines on tdo4
You have to clock the turbo so oil return pipe facing down!
Go hybrid mate that ct20/ct9 turbo that's for sale is the tits and bargin for 200 ask shorty he had one to at some point
  nazzurro19 said:
daz youve recently gone td04 what bar u runing and what engine specs whats the difference like ? i dont mind lag if i get such a massive boost in power that i can make the lag time back if ya get me
carnt realy coment yet mate as its only running .5bar till i get a clutch and get it mapped.
im running 1.1 bar on my TDO4 set up with standard engine but everything to support the tdo4 kit, its amazing hardly no lag what so ever and when full power comes in its lushness! also set the ebc so the turbo spools in sexy,simples, you will not be dissapointed its so fast
here is my spec
Reconditioned Race-Tech TDO4 Turbo
Killimats- Manifold,External Wastegate,Decat and Screamer Pipe, Oil & Water Lines
Autobahn/EBAY? FMIC
JAM ECU
Gizzmo EBC
Sard Rad Cap 1.3 bar
Power Getter Exhaust System
TD Fuel Pump
A-Tech Wheels/Parada Spec 2 Tyres 195/50/15
RSR Lowering Springs/Jap Coilovers
NGK heat range 7 spark plugs
