thinking of either selling or stripping my car to get a bigger car.
will see what the interest is like first,and figures.
the spec is..
Engine;
Wisco Low Compression Pistons 74.5mm
Scat H-Beam Forged Conrods
ACL Bottom End Race Bearing Kit
...Block Professionally Rebored and Honed
ZEP 1.2mm Head Gasket
Ported and Polished Head
Heavy Duty Valve Springs
265deg Billet Cams with 8mm Lift
New Toyota Cambelt Kit
New Toyota Water Pump
New Toyota Oil Pump
New Toyota Engine Gasket Set
removed power steering, and aircon (has single pully on the crank.
-magnicore leads
jperformance fmic (custom hot side for shortest route)
intercooler spray (home made)
toyo sports aluminium civic radiator
wepr manifold
ricky-lee decat pipe
zigen5 exhaust
external wastegate (brand that zisco use)
vf23 roller bearing turbo
side exit screamer pipe
newish breather filter
genuine trd oil cap
poly bush left n right engine mounts, not rear.
k+n induction filter
helix autosport 4puk paddle clutch
has a low mileage gt gearbox
manual boost controller (12psi)
adjustable fuel pressure regulator
magnetic sump plug
147km on the shell,then i put a speedo converter on it.
engine has done just under 9k,
laguna splitter
fibre glass canards
team dynamic's pro 1.2's 15"
d2 coilovers
front strut brace
rear optional extra strut brace
recaro front seats, on recaro rails
sparco d/s 3 point harness
taxed for 6months today. mot due on 11th so will have new mot also.
glanza is getting new rear discs/bearings and abs rings +pads before mot too.
to point out there will be new mirrors too,as the ones currently on the car are broke.
the boot is obviously sprayed matt black,but i have the silver boot too,just has no glass in it but will be included.
thanks
Really like the look of this ;) Is that the screamer pipe coming out the front bumper??
I think you would make more in parts but its a nightmare ;)
Maybe £3000
its hard to say esepcially when a lot aren't selling at the moment.if i had the money i'd have it off you as its got quite a bit done,wouldn't need to do anything.
as the ad says mate "side exit screamer pipe"
:p Ooops missed that :lol:
4k cash. but ill not be stripping anything till the engine is sold.
because if it doesnt sell ill get it mapped.
i was looking for £4300, just needs injestors and mapped and itll be 320+bhp
what power do you think its running just now at 0.8?
