ep91steve Posted April 5, 2011 Posted April 5, 2011 Just put oil in car and noticed gunk in oil cap.. And using water out off coolant bottleNow the car overheated twice jue to gasket knackerd on water lines. Be lucky if it over heated for 2minz before a noticedCar runs fine! Would you adivse not to driveAlso what gasket will a get? Am forged running 1.1bar hybrid cams etc Quote
pagey Posted April 5, 2011 Posted April 5, 2011 Just put oil in car and noticed gunk in oil cap.. And using water out off coolant bottleNow the car overheated twice jue to gasket knackerd on water lines. Be lucky if it over heated for 2minz before a noticedCar runs fine! Would you adivse not to driveAlso what gasket will a get? Am forged running 1.1bar hybrid cams etcdont travel long distances and keep an eye on your water also get it fixed asap Quote
LeeG Posted April 5, 2011 Posted April 5, 2011 check the head bolts are torqed to right settings mate before takin the head off it. mines was same after aput it back togeher leaking at same place but didnt overheat. slackend head bolt at tht side then retorque them to factory settings not leaked since.it pass its mot?? Quote
ep91steve Posted April 5, 2011 Author Posted April 5, 2011 Lee engine been in car for 2yearsNo mot yet mate going to garage tomorrow now, am seriously pissed off with this car once mot'd be off road again getting pissed off with this car tbh, fucks up one more time am going to break it for sure Quote
LeeG Posted April 5, 2011 Posted April 5, 2011 try re torqin them first as u only need to remove rocker cover. if it is fuked get a athen metal headgasket mate.http://cgi.ebay.co.uk/TOYOTA-STARLET-GLANZ...=item45f9c32ef1 Quote
daz gt turbz Posted April 5, 2011 Posted April 5, 2011 not having much luck with it are you dude! hope you get it all sorted tho, be worth it in the end! Quote
lukEp Posted April 5, 2011 Posted April 5, 2011 Have you got a picture of how youve plumed in your catch can? Quote
ep91steve Posted April 5, 2011 Author Posted April 5, 2011 Will do the aboveLuke no catch tank just breather on rockerLee enzo sells they gaskets cheeper and that's what am goin for Quote
LeeG Posted April 5, 2011 Posted April 5, 2011 kl couldnt remember the name of they hg. thts why i put up link lol Quote
ep91steve Posted April 6, 2011 Author Posted April 6, 2011 Going to have mate standard or metal fo as standard is 1.2mm Quote
LeeG Posted April 6, 2011 Posted April 6, 2011 defo metal one then matey. whos done head gasket for yee?? Quote
ep91steve Posted April 6, 2011 Author Posted April 6, 2011 Prob the girls dads garage Mvm car there the now. For getting up to mot standard then mot, fingers crossed it don't cost me much so a can get head gasket done it for end off month Quote
rob2.2 Posted April 6, 2011 Posted April 6, 2011 DO NOT DRIVE IT AS IT WILL MAKE IT WORSE!!!!!!!!!!!!!!!!get it sorted as soon as possible mate, im doing mine as we speak and its a nice easy job dont travel long distances and keep an eye on your water also get it fixed asap Quote
ep91steve Posted April 7, 2011 Author Posted April 7, 2011 Update car at gargae getting mot work done... They said that a have put 2litre to much of oil in! And that's what more and likey caused the gunk, and that headgasket should be fine? True? Quote
ep91steve Posted April 7, 2011 Author Posted April 7, 2011 Right car at garage the now! They said a put 2litre to much of oil in the car (tit a am),they said that could be the problem. Oil is clear not milky or that, heaters working as far as a member. No smoke out off exhaust more like condensation and car has only been started up few times in last 2 month for about ten minz max Quote
Socks Posted April 8, 2011 Posted April 8, 2011 cant see how too much oil wud make it overheat and use oil mate... Quote
ep91steve Posted April 8, 2011 Author Posted April 8, 2011 Only lost water jue to water line gasket been nackerd Quote
whiteglanzav Posted April 8, 2011 Posted April 8, 2011 too much oil can make it burn oil due to over pressurisation Quote
