nutnut Posted April 11, 2011 Posted April 11, 2011 On my glanza I have the oil sensor in the original placeI have a sandwich plate fitted so I could install the oil gaugeThe problem I have is Drive normal with some boost the oil light won't come on which is fineDrive the car hard with lots of boost & the oil light will flicker when I stop !Also the oil level is bang on the max line .I'm using magnatec oil Thank you if you could help as I want to go to santa pod Easter weekend in the car & want it working good. Quote
MARC MOSS Posted April 11, 2011 Posted April 11, 2011 i get a flicker randomly from mine then it stops and then starts doing it again when ever it fancies it... and this has happened for years of thrashing nowmy oil pressure gauge states there is no problem at all so i ignore it, fkin toyotas lol Quote
Danturbo4311 Posted April 11, 2011 Posted April 11, 2011 Check the wire going to the oil pressure switch may have rubbed through somewhere if it earths out on the block it will bring the light on that would explain why it does it randomly. Quote
nutnut Posted April 11, 2011 Author Posted April 11, 2011 it only flickers after very hard drivingwhich is what i cant work out.if it was earthing out it it would flicker after short bursts of boost !what psi should be reading on the gauge when sitting idle ? Quote
nutnut Posted April 13, 2011 Author Posted April 13, 2011 any other ideasChecked all the wires all connected ok Problem is still there Quote
WallaceGlanza Posted April 14, 2011 Posted April 14, 2011 You've got low oil pressure when the cars been given a bootful as the oil will be hotter and thinner hence the pump won't be working as hard to pump the oil so less pressure. If the pressure is dropping low enough to bring the light on a new pump might be needed. Quote
nutnut Posted April 14, 2011 Author Posted April 14, 2011 You've got low oil pressure when the cars been given a bootful as the oil will be hotter and thinner hence the pump won't be working as hard to pump the oil so less pressure. If the pressure is dropping low enough to bring the light on a new pump might be needed.the pressure is low when the light is onI was dreading to hear that answer of a new pump neededAre they hard to fit ? Quote
