Right, well the other day, my interior light stopped working.
I have changed the bulb, and its still not working.
Is there a fuse for it? I thought it was on the interior one with the cd player and clock. but they are both still working
is there an engine bay fuse for it?
My clock is really dim a lot of the time, but i dont know if that is related. head unit works fine.
Any ideas? thanks guys
Take the cover off and check the connections inside, while your at it get a multimeter and put it across the terminals and test to see if you getting any voltage on the light its self, there should be just the one fuse for it.
if i put it on doors only, then the lights on the dash come on to say the door is open, but the interior light doesnt actually light up
will try and get a multimeter to test it :\
no its all the points where the rivets go through.
what ive done is drilled out all the rivets
cleaned up the connections
put about 2-3mm bolts through
ive not tested it yet but hopefully it will work
Marck
