The two hoses under the coolant hose in the picture, I think there oil feeds, they go into the back of the turbo, if I disconnect them am I going to get oil gushing everywhere or will it be alright?
Cheers
Ross
youll have water comming out, they are the coolant lines for the turbo......just use one hose and loop it if you dont want to run them to the turbo
Right all that is holding the turbo on now is this blue pipe and the arm that comes off and into the block.
Can these be remove without oil coming out or not?
Cheers
Just standard ct9 ATM, my hybrids fucked so temporary downgrade.
In other news it's back together now. Shitting myself and don't wanna turn it on though, never done a turbo and got visions of it going bang!
Just started her up and there's some smoke coming from off the manifold, do you think this is just a bit of spilt oil or something.
Cheers
Ye I did mate, the smoke is because coolant is leaking from somewhere and Burning :thumbsup: , most likely from the back of the turbo which is a bitch to get to.
