wssoR Posted April 19, 2011 Share Posted April 19, 2011 Where have you run your power cable through the firewall?Cheers Quote Link to post Share on other sites
bucketep91 Posted April 19, 2011 Share Posted April 19, 2011 there is a little gromet behinnd the glove box, you will see it in the bay. pop the grommet out and shine a torch through and you will see the light from the other end, feed your power wire through job done! Quote Link to post Share on other sites
Gainzy Posted April 19, 2011 Share Posted April 19, 2011 i used a few glow sticks from pound land fed them through lol yeah those gromits can be fiddley things Quote Link to post Share on other sites
Starbuck Posted April 19, 2011 Share Posted April 19, 2011 JapLuvA said: Where have you run your power cable through the firewall?CheersI run mine through the gromit above the aircon lines. unravel a coat hanger, tape the lead to the end of the wire. Push wire though firewall until you can see it in the footwell. Remove it from the wire...... Quote Link to post Share on other sites
