Ashy Posted April 23, 2011 Share Posted April 23, 2011 Still having problems with blitz ecuHi guys I recently bought a blitz ecu for my Glanza at 1st I just plugged it in and started driving.it wasn't running good at all so I plugged it out for a couple of minutes and plugged it back in again and let it idle for about 45 minutes and drove easy for about 100 miles,after this i took it on the motorway and drove the car pretty hard and it was fine but took it out today and at about 5k revs the car judders feels a bit like a misfire then it runs fine again it doesn't do this in 1st gear and sometimes it doesn't do it all.getting really pissed off now.I've recently changed the spark plugs with some basic ngk ones and got some ultra leads aswell my other mods are cat back exhaust and bypassed the boost selonid.it's currently boosting at 0.7 but does creep up to 0.8 and when its cold it creeps upto 0.9 Please help guys getting really frustrated Quote Link to post Share on other sites
Amjad Posted April 23, 2011 Share Posted April 23, 2011 Try this, unplug it for 30 mins, plug it in and start it up. Let it idle for about 15-20 mins (it will probably idle a bit wobbly over this period) then blip it a few times up to say 2/3000 rpm so the idle lowers and stabilises.Leave it to idle for a further 10/15 minutes after which the idle should be stable at 900rpm!Take it for a gentle drive, bring in boost after a few minutes, but gently ie don't take it to full boost across the rev range yet. Let the car cool and shut it off. Let it cool further and then take it for another drive, gradually riving it harder until you get full power.I did exactly that for my Mine's ECU, and it works like a dream. Looking at your problem I'd have thought it'd be ignition related but have you checked Dizzy, rotor arm & timing? Quote Link to post Share on other sites
Ashy Posted April 24, 2011 Author Share Posted April 24, 2011 Will try that tomorrow.what would I look out for on the dizzy cap and rotor arm?and how do I check timing?thanks Quote Link to post Share on other sites
_shaun_ Posted April 24, 2011 Share Posted April 24, 2011 mine was missing higher up the rev range and turned out to the rotor/dizzy think it was like £30 for new 1s so prob worth doing just so its all fresh anyway Quote Link to post Share on other sites
Ashy Posted April 24, 2011 Author Share Posted April 24, 2011 Where did you get yours from mate?I was thinking it could be something like that too but I don't know much about cars.still learning lol. Thanks Quote Link to post Share on other sites
_shaun_ Posted April 24, 2011 Share Posted April 24, 2011 any motorfactor /toyota dealer will be able to get them Quote Link to post Share on other sites
Ashy Posted April 24, 2011 Author Share Posted April 24, 2011 Ok thank you mate Quote Link to post Share on other sites
damien Posted April 26, 2011 Share Posted April 26, 2011 and there was me thinking i was the only person with this problem. i have a toms ecu the car pulls well up to 4000rpm then it goes flat feels like it has a slight miss then when it gets to 5000rpm it pulls really hard if i unplug the ecu to reset it it will run ok for a short while. i have changed everything leeds plugs dizzy unit rotor arm dizzy cap fuel pump injectors fuel regulator new turbo lamda sensor knock sensor timming inlet manifold gasket checked all piping for leaks its driving me mad i just want to no what it is because everything on the engine is new lol also to add ive tried another map sensor coil and the silver igniter unit and different fuels and fuel fillter Quote Link to post Share on other sites
kdowg Posted April 26, 2011 Share Posted April 26, 2011 damien said: and there was me thinking i was the only person with this problem. i have a toms ecu the car pulls well up to 4000rpm then it goes flat feels like it has a slight miss then when it gets to 5000rpm it pulls really hard if i unplug the ecu to reset it it will run ok for a short while. i have changed everything leeds plugs dizzy unit rotor arm dizzy cap fuel pump injectors fuel regulator new turbo lamda sensor knock sensor timming inlet manifold gasket checked all piping for leaks its driving me mad i just want to no what it is because everything on the engine is new loli have this problem between 3/4k and its still on a standard ecu bin like it since i bought the car last june driving me mad now like just fed up with it if im honest I've changed everything over and still noo joy. any of you lot find a cure will let me know so i can try it on my car cheersdan Quote Link to post Share on other sites
damien Posted April 26, 2011 Share Posted April 26, 2011 kdowg said: i have this problem between 3/4k and its still on a standard ecu bin like it since i bought the car last june driving me mad now like just fed up with it if im honest I've changed everything over and still noo joy. any of you lot find a cure will let me know so i can try it on my car cheersdando you have a stainless manifold i had a cheap ebay manifold and this gave me that problem at 3/4k as the size of the bores was much larger then the ports on the head allowing the exhaust gases to expand and slow down when coming out of the engine removed the crappy manifold and car run well until i got my new problem lol Quote Link to post Share on other sites
damien Posted April 27, 2011 Share Posted April 27, 2011 damien said: do you have a stainless manifold i had a cheap ebay manifold and this gave me that problem at 3/4k as the size of the bores was much larger then the ports on the head allowing the exhaust gases to expand and slow down when coming out of the engine removed the crappy manifold and car run well until i got my new problem lolanyone found an answer to our problem yet???? Quote Link to post Share on other sites
mrsilly Posted May 9, 2011 Share Posted May 9, 2011 damien said: anyone found an answer to our problem yet????I've had this problem for a while. I was down seeing a mate at the weekend and mentioned it to him, he said to connect the rocker cover breather back to the air intake to reduce the pressure (i currently have a breather filter on my rocker cover). I haven't had time to try it yet but will give it a bash this week. Quote Link to post Share on other sites
