jham Posted April 27, 2011 Posted April 27, 2011 Hello,Just anout to buy some rear discs to match the fronts ive got coming from sparky,DOnt know if my car has ABS and it looks like theres 2 different types of disc.My car is a 1993 Mk2 GT any one know from that?cheers Quote
yaristurbo Posted April 27, 2011 Posted April 27, 2011 Check for a abs pump under the bonnet, metal block with brake lines coming from it, abs light on dash when ignition first switched on, and a abs ring on the out driveshaft cv joint. Some one might be able to tell you I don't know just from the model and year sorry Quote
chris H Posted April 27, 2011 Posted April 27, 2011 Just stamp on the brake pedal at 30mph and you'll soon find out matey Quote
Sparky Posted April 27, 2011 Posted April 27, 2011 Not if it doesnt work like mine didnt ^^^ lolCheck under the bonnet mate, it may say on the VIN plate or inside the door shut maybe? Quote
jham Posted April 27, 2011 Author Posted April 27, 2011 Cheers ill check now... Those discs your selling sparky are the for abs or non abs? Quote
RobSR Posted April 28, 2011 Posted April 28, 2011 if your still unsure, upload a pic of your engine bay, and we'll tell ya Quote
d-a-n Posted July 29, 2011 Posted July 29, 2011 Or see whether your fusebox has an ABS fuse in it. The map on the lid of the fusebox will show you where it should be. Quote
nazzurro19 Posted July 29, 2011 Posted July 29, 2011 it dont matter anyway cause the abs brakes just have a collor on that u pull off with a screwdriverjust means ya waste £20 if ya aint sure lol Quote
