Hi guys
I'd like to upgrade from the standard to distributor to coil pack, has anyone on here done this conversion?
Any information would be great, ie. what parts I need and whether the conversion is worth the hassle.
Cheers
Idrees
Do you fancy a swap for a distributor? :D
I'll hunt the scrap yards for one if someone can confirm what else I need.
yea not sure what management u need to run for it tho think i seen it can be done on an emu . wont be cheap but looks the dogs bollocks
you need ecu that can run them for a start!! people use differant type of coils!! loads to chose from,and just wire them up,youl also need to sort your leads out aswel..could have a set coming up for sale soon.wouldnt be cheap doh!
  • 3 weeks later...
