hey guys
just woundering if there is anyway of telling if a shifter unit is trd the guy says it comes with washers/spacers if that helps
is there any stamps or marking on it to tell if it trd
thanks
joel
ive got a trd and theres no markings as far as im aware its only trd units that come built and literally swap over
all the other ones ive seen use the standard white housing but then u change the internals
Ask for a pic from above, or from directly behind, trd unit is bent towards the driver.
Thats stock in the pics as the rubber bushings are pressed into the base, trd unit has metal washers that go under the unit and are loose, no rubber bushings are pressed into the base at all.
hmm maybe it is standard but the standard one i took from my GT had a straight shifter not a kinked one
mine looks like this
n now i think ive been ripped off
see this is my standard one
It says
Exclamation Gear Shifter Comparison (Standard Vs TRD)
Below are some detailed photos so that you can see the differences between the two units. It is evident that the following differs between the two:
The lever itself (the metal rod) is shorter above the pivot point, and is bent in towards the driver
The length of the rod below the pivot point is greater by 12mm on the TRD unit in comparison to the standard unit.
You will notice that when placed on a level surface, the rod has a clearance (approx. 5mm) on the standard unit, however is touching the surface on the TRD unit.
The return spring action mechanism differs slightly as illustrated in the photos. This is not due to it being a TRD unit, but rather the change they made between EP82 and EP91 gear shifter assemblies.
Note that the brown looking unit is from an EP82 vehicle, and the white unit is TRD designed for the EP91. After personally comparing the differences between the standard EP82 and EP91 gear shifter assemblies I was not able to notice any real differences that would affect performance (the mouldings slightly differed but nothing that would impact drivability).
http://www.ep91.com/attachment.php?attachm...mp;d=1187144904
if they don't work now, i cba.
