Calling SR owners!
Calling all SR owners, i need your help.
i need to ask a massive favour. i need pictures of the plugs that plug into the back of the dials to see how they wire up!
this is an urgent call for help! please help people!
dont know if this will work with paseo but did with my glanza ones..
take both dials apart and swap the bottom black igniton light cover things including the top 2 indicator ones from your SR dials to the paseo. Put them back together and swap the green board on the back off them over. So the paseo dials should work the same as SR dials then. could be wrong but worked on my glanza ones :/
Can you not just look at the plugs and then the back of the clocks? Should be pretty simple?
tried that but still not working :p as i dont know what colour wires are for what, tried goin off the guide for the sportif to paseo but the sr is different to them
If it will help below are photos of the 3 plugs from a sportif that I fitted SR clocks into? I can't remember if the photos are before or after the conversion though.
The photos might be able to help you but I'm sorry if there no help at all!
Gavin
