adam ep Posted June 1, 2011 Posted June 1, 2011 can i remove the power steering in my glanza and just plug up the holes in the rack? has it been done? or am i better off the find a ep91 with no power steering and use that rack? Quote
N80Jamie Posted June 1, 2011 Posted June 1, 2011 Fairly certain your going to need the non power steering rack dude ;) Quote
adam ep Posted June 1, 2011 Author Posted June 1, 2011 did some of the early spec 96 starlets coming in non power steering aswell? i mean standard spec starlets not glanzas Quote
Liam_D Posted June 1, 2011 Posted June 1, 2011 Think the early spec EP91 N/as came without power steering mate. Quote
GT Phayer Posted June 1, 2011 Posted June 1, 2011 one of my mates was using the standard rack just put grease in it to keep it lubed up mate you cant block it off as the pressure will build up needs to be open Quote
greasemonkeyspb Posted June 1, 2011 Posted June 1, 2011 need standard one mate ideally early n/a starlets have em as said above fluid pressure in rack so cant block it off Quote
adam ep Posted June 1, 2011 Author Posted June 1, 2011 ok thanks guys, on the hunt for a new rack then ;) Quote
