Just removed Air Con Evaporator.
had the dash out, checked every single connection even the ones not related to the fan but can't find anything amiss. I am baffled tbh.
How many wires are suppost to be coming out of the fan speed control plug?
I think mine had 2 :S
on the guide on the top ,check pic step 3 ,the sensor have you connected this back,this unit that control the speed..check that...all the plugs..hope that help Raz..
if it only works on full theres a problem with the resistor either the resistor itself or wiring to it as on full power it doesnt us the resistor to run the heater fan if that makes sence
Well, once i put everything on and it wasn't working. i had the sensor and pliers in my hand.(while i was thinking wtf) So i pulled all the metal tabs out of it shattering the white stuff which was crumbling down on to the road and all the tabs have been twisted and shit when i tried to pull it out. Which i did eventually pull out and throw on the grass lol
