right finally getting round to sorting some power out. ive got a list of bits want to know if you guys think i needed anything esle. :)
heres the stuff ive already got on the car
-blitz nur r spec exhaust system
-blitz dump valve
-japspeed decat
-blitz sus induction
-hks fuel cut defender
-hks actuator
-blue silcone rad hoses
-A/C removed
-Cusco oil catch tank
-sliver fse competion rrfr
-walbro fuel pump
-sard rad (not fitted)
-greddy oil cooler (not fitted)
and the bits i want
Forged engine
Ported head
Lightened crank
Valve springs
PE cam belt
Quaife
TRD quickshift (maybe)
Aluminium Anodised Lightweight Pulleys blue
TRD E/mounts
R/spec rocker
AEM AFR
550 injs
unsure which ecu to get and id be getting a racetech td05 kit with one of there fmics.
cheers lew
All depends on what boost you want to run.
Td05 @1.1 bar should see you around 250 brake if you include the parts above
As for ecu, again all depends on what features your after.
Idrees is selling his race tech td05 kit & inlet manifold. I think a inlet is a must with a td05 because of the lag!
Pretty sure emanage ultimate has the launch control feature - hes selling that aswell lol
im going with emu with mine mate running a td05 hybrid at 2 bar as im told the emu has the option to run launch control but might be wrong :) and gives a better tune
And 550cc injectors, Idrees is your man :)
:D
Take a look?
Damn! What power you looking to achieve?
250 to 300? i'd either go td04 on a forged engine. thats 270 to 280 at 1.5. cheap turbos to replace etc. or the racetech 300 kit that matt has on his v. thats supposed to run 300+ with similar spool to td04.
