Jamie1st Posted June 22, 2011 Share Posted June 22, 2011 I've got a FCD you can have, still in my car now, working fine. £55 posted. Drop me a PM.Jamie Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 I've got a FCD you can have, still in my car now, working fine. £55 posted. Drop me a PM.Jamiecheers mate will give u a pm if i need to replace thanx. Quote Link to post Share on other sites
templar2007 Posted June 22, 2011 Share Posted June 22, 2011 Mate have you got the kid number still to find out witch one it is for people to help Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 it has a hks actuator and if by wastegate u mean dumpvalve it has a bailey dump valve Quote Link to post Share on other sites
templar2007 Posted June 22, 2011 Share Posted June 22, 2011 That good then you got a hks actuator I think that's how your boost will be controlled. I think its you fuel cut mate I think standard is about .6 bar so when your boosting at .8 your hitting the fuel cut and that why your car doin That and ok when you drive normal Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 That good then you got a hks actuator I think that's how your boost will be controlled. I think its you fuel cut mate I think standard is about .6 bar so when your boosting at .8 your hitting the fuel cut and that why your car doin That and ok when you drive normalwere does the fuel cut switch thing go because the lad said it allready had an hks one shouldnt that be able to take the boost? if its there at all lol Quote Link to post Share on other sites
Raz Posted June 22, 2011 Share Posted June 22, 2011 yh, it says he allready has a HKS FCD, You will need to find it on the car, or ask the lad where is it. You are looking for something like this: Quote Link to post Share on other sites
templar2007 Posted June 22, 2011 Share Posted June 22, 2011 yh, it says he allready has a HKS FCD, You will need to find it on the car, or ask the lad where is it. You are looking for something like this:Ya but if its fucked that could be why or not Quote Link to post Share on other sites
Raz Posted June 22, 2011 Share Posted June 22, 2011 yh if its fucked then its not going to work is it. How sure are you that its fucked. other then the face your hitting fuel cut lol, But not all the time? It might just need to be re adjusted? Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 yh if its fucked then its not going to work is it. How sure are you that its fucked. other then the face your hitting fuel cut lol, But not all the time? It might just need to be re adjusted?any ideas were this unit is usally put and how to tell if its not working right i cant get in touch with the kid who sold me it Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 bump Quote Link to post Share on other sites
Raz Posted June 22, 2011 Share Posted June 22, 2011 glove compartmentbehind dashi dunno :s Quote Link to post Share on other sites
Torturedglitch Posted June 22, 2011 Author Share Posted June 22, 2011 glove compartmentbehind dashi dunno :sno worries i will have a look around car hopefully have it fixed before JAE lol cheers for advice Quote Link to post Share on other sites
BearFaceOfDoom Posted June 23, 2011 Share Posted June 23, 2011 You got a turbo timer on it? Quote Link to post Share on other sites
Braad Posted June 23, 2011 Share Posted June 23, 2011 Right, I'm the 'kid' who he bought the car off.First a few things to get clear :1) Boost is a adjustable actuator which is set to 0.8 Bar, however I've known it to creep just past to around 0.9(Occasionally depending on circumstances)>2) It has a HKS FCD which is behind the glove compartment, I never ever touched it from when I bought it but was setup to 0.8. 3) It has a turbo timer, a blitz one. Funny thing is the day I bought the car home it was torrential rain and did the exact thing, felt like engine was cutting out and juddering, but wouldn't do it if you built the boost up gradually. How did i fix the problem at the time? Replace the spark plugs, problem gone (Water had go in through the vent). So changed spark plugs and see what happens!One thing to consider is the Air filter being so close to the vent, possibly taking in water? I'm no experts but that could be considered.Just to clear my name here, I've not sold a 'lemon' car ran fine apart from the clatter which was clearly described and agreed by Paul (sticky lifter, shim problem). Like advised, don't go ragging the nuts off it until you've checked! I'm no expert but will try and help as much as i can here.Finally, I've not had any calls from you so I wouldn't of known, and if i did I would of been on here to help! Quote Link to post Share on other sites
Torturedglitch Posted June 23, 2011 Author Share Posted June 23, 2011 Right, I'm the 'kid' who he bought the car off.First a few things to get clear :1) Boost is a adjustable actuator which is set to 0.8 Bar, however I've known it to creep just past to around 0.9(Occasionally depending on circumstances)>2) It has a HKS FCD which is behind the glove compartment, I never ever touched it from when I bought it but was setup to 0.8. 3) It has a turbo timer, a blitz one. Funny thing is the day I bought the car home it was torrential rain and did the exact thing, felt like engine was cutting out and juddering, but wouldn't do it if you built the boost up gradually. How did i fix the problem at the time? Replace the spark plugs, problem gone (Water had go in through the vent). So changed spark plugs and see what happens!One thing to consider is the Air filter being so close to the vent, possibly taking in water? I'm no experts but that could be considered.Just to clear my name here, I've not sold a 'lemon' car ran fine apart from the clatter which was clearly described and agreed by Paul (sticky lifter, shim problem). Like advised, don't go ragging the nuts off it until you've checked! I'm no expert but will try and help as much as i can here.Finally, I've not had any calls from you so I wouldn't of known, and if i did I would of been on here to help!ye cheers brad, been trying to get hold of ya but i think my iphone is playing up will check the fcd tmrw as am going to work soon . Quote Link to post Share on other sites
