started my n/a and i just moved it. i let it idle while i was loading some wheels, it died now it wont start help guys please its my daily runner and im screwed with out it
cheers ;)
no good ry and i had no luck she turns thats it. my dad thinks its electrics or fuelling but it ran fine and just died which is weird as i filled up last night drove it around fine. it baffles me
if it becomes too expensive to repair its going dont get me wrong i love it but my wallet wont.
when u say u were just loading sum wheel u not damaged the fuel pump or knocked a kill switch sumwhere?
the wheel fits in the boot fine and i dont think i have a kill switch or damaged the fuel pump.
i remember in my old xr3i the kill switch was in the boot under spare tyre dunno if starlets have but could be worth a look
Spark plug in a lead, stick it to engine some where? Any spark????
With that plug out smell clyinder, any fuel?
Injector feed pipe off good flow of fuel ******do this after checking all leads have sparks*******
checked the leads and plugs are fine. i could smell fuel in the cylinders when i took them out.
it either sounds more like a timiing issue or choke issue maybe? checck all your vac hoses are still on and ok and then
id suggest checking the timing belt and seeing if its still timed up correctly
Hi there, just a thought but, Just a few things to check going by the symptoms you've reported. (P.s AT YOUR OWN RISK, so if what I suggest goes wrong, don't blame me lol!.)
Any DTC's ( Engine warning light/ Engine Codes )
From experience and the Toyota manual, poss causes and to check the following
under the following symptoms, the same 1st thing to check occurs, and from what you wrote " Filled up last night" looks plausible you might have dodgy or contaminated fuel?
Symptoms:
Difficult to Start/ Normal Condition.
Poor Idling / Rough Idle/ Misfire.
Poor Driveability/ Knocking.
Engine Stall Soon after Starting.
(All point to for first check)
1. Fuel Quality.
Other things I would be checking, not in any particular order but preference imo :
Electrical Plugs & Connectors behind Glove Box & in Engine bay
15A EFI Fuse & EFI Relay
15A AM1 Fuse
Spark Plugs
Valve Timing (Cam Timing Belt)
Temp sensor
Distributor/ Igniter assy.
Hope this helps. Cheers, Greasemonkey.
Just had a thought, micras after short journeys flood, I know it's not a micra but worth checking, either remove the fuel pump fuse or clamp off the injector feed fuel line and crank it over for a few times. Do this with plugs out or in, more effective with them out . Get it put back together and try and start it
